Page 1 of 2 12 LastLast
Results 1 to 25 of 38
Like Tree8Likes
Thread: Whats this part called? leaking water
    1994 Hilux V6
    Sep 2010
    Newcastle
    Default Whats this part called? leaking water
    ive had to top up the water in my radiator heaps in the last week, since it started getting hot out of no where. i think i have figured out whats leaking but i dont know what its called. on idle it drips a little bit, but took it for a drive and then looked under the bonnet and there was water everywhere underneath it and leaking down onto the ground.
    does anyway know what its called and how much they are to replace?
    cheers
    Attached Thumbnails Attached Thumbnails Whats this part called? leaking water-img_0288.jpg
    1994 Hilux V6
    Sep 2010
    Newcastle
    VX SS M6
    Mar 2008
    WA, SoTR
    Its called a Heater Tap,
    Shouldn't be too much to replace, Repco and the likes should have a aftermarket version.
    Just be sure its the tap that leaking, not the cords in the hose weeping
    VN
    Dec 2011
    Same thing went on my VN, 45bucks from Repco. Or 40bucks from the wreckers lol.
    1994 Hilux V6
    Sep 2010
    Newcastle
    im not exactly sure that its the heater tap, but thats where all the water is coming from.
    are they a common problem for leaking?
    ill get a replacement one and if it stil leaks from there then well it must be the hoses
    VN
    Dec 2011
    Quote Originally Posted by kid_720datto View Post
    Heater valve tap is what it's called.
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    Brittle plastic. It gets old and cracks. Will happen once every ten years or soo.
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    Commodore M6
    Jul 2010
    East Coast
    1994 Hilux V6
    Sep 2010
    Newcastle
    thanks for the info, going to get one on thursday.
    r they just a simple swap over job or should i be weary about somethings?
    VN
    Dec 2011
    Took my mate 5mins to do mine, if that. I would of done it myself but he was buying the car off me lol
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    you can get them off ebay for less then 20 bucks however i dont kow how good teh quality is, im pretty sure there the same as the ones repco sell, or used to sell as now its all there own branded stuff but yeh
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Double post. I'm having trouble with this forum lately.
    MY RIDE
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    May I suggest that when you replace it that you flush the system and fill it with the correct coolant. From the photo it looks like just rusty water leaking without a trace of coolant, that will lead to more problems down the track, because things are corroding in there. Oh, and bleed the system when you are done or it will probably overheat.
    MY RIDE
    vx custom 600RR
    Oct 2010
    as above and try not to pull at the hoses going to the heated core and save yourself some heart ache
  15. #15
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by Bombaman View Post
    Quote Originally Posted by 51QAS View Post
    Quote Originally Posted by TonyJZX View Post
    it's a tap heater
    Its a thermal exchanger vacuum controller actuator valve actually.
  16. #16
    '97 VS Commodore Wagon
    Jul 2011
  17. #17
    VN
    Dec 2011
    Quote Originally Posted by PaRaDoX View Post
    google vt heater valve tap and it will come up, I'm sure the boys at Repco will know what you're talking about anyways.
  18. #18
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Good luck asking anyone for that and getting the part.
    Silver Certified.
  19. #19
    VY SS
    May 2011
    Auckland
    Given that it's summer and you dont really need a heater, you can temporarily bypass it so your car doesn't overheat.
  20. #20
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Some of the boys at repco couldn't tell a heater tap from a pineapple.
  21. #21
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    That's the orange one yeah?
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  22. #22
    Jan 2008
    NSW
  23. #23
    1994 Hilux V6
    Sep 2010
    Newcastle
    going to get the heater tap (or what ever it is called) tomorrow from supercheap, and also coolant and flush.
    one more thing, im not exactly sure on how to flush my radiator, despite having searched nearly a billion different threads. i was going to do it this way,
    pour in the flush and run for 20 minutes, maybe even a drive, then when the engines cold, take off bottom and top radiator hoses, turn heater to hot and full, take out thermostat and run a garden hose through the top hose til it comes out clear out the bottom hose. then put everything back on. should i undo the screw in the thermo now?
    then to refill do i pour in the coolant until it fills the radiator then run the engine and continue to fill while coolant circulates the engine?
  24. #24
    VY SS
    May 2011
    Auckland
    That will work. When the flush is in three make sure your heater is on full bore
  25. #25
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    prolly wouldnt hurt doing the heater hoses while ur at it, might saving u from doing it again later if they have never been changed b4.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  1. help whats this part called
    By GM GEN3 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-03-2011, 07:33 PM
  2. What would this part be called?
    By xdefectedx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-02-2010, 01:26 AM
  3. Whats this part called, Oil pressure switch screws into ... ?
    By greenacc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2009, 10:43 PM
  4. what is this part called?
    By ssmate in forum General
    Last Post: 09-06-2009, 03:53 PM
  5. what is this part called?
    By gendi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2008, 09:20 PM
