Results 1 to 16 of 16
Thread: info on changing a radiator support panel
    vb and vx commodore
    Jan 2012
    narromine
    Default info on changing a radiator support panel
    hi, i was just wondering if it was legal to replace the radiator support panel or does it have to be done by a repairer, as it has an info plate on it as i have heard youre not allowed to remove it (the plate)? i know how, just wondering if im allowed to by law.
    thanks
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    Why would you want to remove the plate. It's there for a reason.
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    vb and vx commodore
    Jan 2012
    narromine
    lmao because its a new support panel so u need to remove it from the old support panel then attach to the new one.
    S.T.K.E's Avatar
    Mar 2009
    Brisbane Northside
    So it a wrecker. Wouldn't see a reason why you couldn't.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    It's spot welded in.
    You need to drill out all the spot welds to remove it, then you need to spot weld the new one on. Unless you can do a good job i wouldnt bother.
    I was going to replace the radiator support in my VP but i found other damage and decided not to.
    vb and vx commodore
    Jan 2012
    narromine
    hey
    i hit a roo in my vx i have went over it and the only damage is to the support panel, light, bonnet
    i have no problems remove the old one and replacing it with the new one the support panel was new
    so i was just asking about the plate with the vin and engine type and trans type on it i allways thought that u couldnt remove them your self it also has one on the firewall
    cheers
    vt s2 sedan
    Apr 2011
    brisbane
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Yes you can,just drill it out and rivet it back on to new panel.You dont need any1s permission for that.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by VTS5 View Post
    I'm not sure i'd rivit it back in but each to their own, It'd prefer the standard look.
    The radiator support panel is NOT structual. its simply there to hold the bonnet down and hold the radiator/condensor.
    vz wagon
    Aug 2006
    Wild west of Melb
    How else would you put the id tag on the new support panel Paradox ?
    My vt has a tag just under the left headlight aswell not sure if the vx has the same.
    VTS5's Avatar
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by PaRaDoX View Post
    FYI,they all pop riveted to the support panel.But,if you like,you can sticky tape it.
    Again,FYI,yes IT IS (as u put it) structural.That hole on the left is (one of the)the measuring hole/s for the engine bay.Try to get it 1mm. wrong!!!! then sit back and watch your claim go down the tube.
    Attached Thumbnails Attached Thumbnails info on changing a radiator support panel-2117.jpg   info on changing a radiator support panel-17.jpg
    vb and vx commodore
    Jan 2012
    narromine
    i was told here from a banelbeater that inspected it in person, that it was nothing structural.
    thanks for all the replys
    i'll be starting the repairs next week, will keep you updated
    VX Executive S2
    May 2006
    Frankston South Vic
    it's a catch 22
    you legaly can replace the radiator support panel but you are not allowed to tamper with the ID plates
    vb and vx commodore
    Jan 2012
    narromine
    Quote Originally Posted by lout View Post
    it's a catch 22
    i thought that was the case as i remember reading some were not to touch the plates but im going to do it and see how it go as rego is end of next month
    so i will find out then lol
  15. #15
    vb and vx commodore
    Jan 2012
    narromine
    also the vin number is not on that plate
    its model, body# ENGINE AND TRANS AND SO ON
  16. #16
    lsx
    lsx is offline
    VT 5.7L M6
    Mar 2012
    newcastle
    Just do it as long as you put the correct plate back down there wont be a problem,
    if you want the standard look cut the stardard rivits from under neith then just glue the plate back down and the rivit will be just for show lol
  1. Radiator support panel?
    By azzfox in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2010, 04:38 PM
  2. VS BT1 Radiator Support Panel.
    By lo-rolla in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2009, 07:02 PM
  3. Vr Vs Radiator Support Panel
    By Keesh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2007, 10:48 PM
  4. Radiator support panel for VS
    By shumway in forum Parts And Other Items For Sale
    Last Post: 17-02-2007, 11:24 AM
  5. Radiator support panel tag
    By Taz2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2004, 09:45 PM
