Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By FstStig
Thread: Torque convertor/flexplate noise
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default Torque convertor/flexplate noise
    Hi Guys,
    for a while now (slowly getting worse) my VT 98 (L67 super 6) makes a metallic clinking noise from the gearbox.
    From what i can tell its coming from the torque convertor and or flex plate.
    I've been under the car while its running on axel stands and im sure that its where the noise is originating.
    Here's the facts.
    -The car makes the noise worse when the front of the car is elevated, and can make it on idle and at low speeds and RPM (normally not at high speeds)
    -The car is fine under high rpm and road speed
    -The Torque converter and gearbox are operating completely normal.
    -In reverse up a steep hill there is no noise whatso ever.
    -The car has a few KM on it.
    I'm thinking the flex plate is cracked, has anyone else had a similar issue?
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    Patience grass hopper. Take it to a trans specialist and get them to drive it. I had a similar noise and torque converter bolts were loose.
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Take the Starter motor out, get a light to shine onto the flex plate and turn the motor by hand until you see the torque converter bolts. There is 3, 16mm bolts. Try and tighten them up. It also helps if you can get someone to hold the motor while you try and tighten them so it doesn't turn.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by Black_Stig View Post
    Hrmm Could be the bolts i'm hoping that over a broken flex plate., I'm familiar with the torque convertor configuration, pulled enough auto's out in my time to never want to do it again.... atleast you can lift a manual box. :P
  1. converter to flexplate torque settings
    By dv8hsv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2011, 01:50 PM
  2. Torque converter or flexplate? Any ideas will help....
    By CHA53R in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2011, 08:07 PM
  3. torque convertor
    By commies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-08-2010, 05:21 PM
  4. Flexplate bolts (torque)
    By REWIRED in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2010, 06:12 PM
  5. vr v6 kaput torque convertor
    By Zuicider in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2009, 07:21 PM
