Results 1 to 4 of 4
Thread: Holden VT Berlina Ignition Issues
    VT Berlina
    Feb 2012
    kyabram
    Default Holden VT Berlina Ignition Issues
    Hi i had an appointment i had to go to today went out to start my car and all i can seem to do is unlock the steering wheel with my keys and than the key seems to just slide all the way around to start with no resistance or spring and nothing turns on accessories, dash pre check lights etc nothing. so i went to the holden dealers and all they had to say was it is my keypad and i had to pay 130 dollars to replace and get it reprogrammed yet im not sure if this is correct or not since my sisters commodore starts without the key in the key pad.. also my keypads central locking etc still works fine would it be the ignition switch busted or barrel? or is holden right any help would be appreciated.
    edit: spent ages trying to find the same identifiable thing happening to me on the web but just cant seem to.
    cheers Justin.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    My bet would be the pin on the bottom of the ignition barrel has broken and is not turning the switch.
    Visit my Facebook page
    VT Berlina
    Feb 2012
    kyabram
    thanks for the reply just been outside looking at the dam thing how do you remove the plastics to get into the barrel dont wanna go snapping the plastics around it.
    cheers.
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Normally I find this problem to be caused by the steering column. You can still salvage your ignition barrel to keep the correct key, the column is held in with 2 13mm bolts and then slides off. You will obviously need to remove the shroud, steering wheel, air bag, clock spring, indicator stalks and key reader. Make sure you disconnect your battery first.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
  1. holden ignition barrel problems
    By badventra in forum General Discussion
    Last Post: 09-02-2011, 05:54 PM
  2. Ignition Issues - Ongoing..
    By cds in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2009, 10:24 AM
  3. Remove VR Berlina Ignition Barrel
    By denidownunder in forum Electrical Wiring / Questions
    Last Post: 06-07-2009, 01:39 PM
  4. VE Berlina - Ignition sense wire ?
    By djm.2305 in forum Electrical Wiring / Questions
    Last Post: 28-02-2009, 01:35 PM
  5. ignition issues
    By Berlinarator in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2006, 10:33 PM
