Results 1 to 13 of 13
Thread: milky brown slime under the radiator cap
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    Default milky brown slime under the radiator cap
    what can cause this??
    leaking inlet manifold gasket?
    tranny fluid?
    or is the head gasket blown?
    if its the tranny fluid will a new radiator fix the problem?
    cheers.
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    It could just be condensation check the other fluids for contamination?
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    oil is fine, no water in oil just sludge under the rad cap and the dipstick is also dirty as hell.
    car doesn't overheat, no smoke, runs and idles fine, i Dont loose coolant.
    VT Calais
    Aug 2010
    How many ks? the engines sweat alot when they get old which creates the sludge.. if you want to do something about it "power" back flush the entire system
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    oil cap and dipstick are fine nothing milky there clean oil by the looks of it.
    just the milky brown shit on the rad cap and the overflow bottle stick is brown dirty to.
    i think it may be oil, as you can see it floating in the green coolant, doesn't have a red tinge to it like tranny fluid has.
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    Then hopefully it's just the bottom tank of the radiator has split... but it still could be the inlet manifold gasket... The harder of the 2 is the inlet manifold gasket as the radiator is just remove and replace.
    Good luck with it...
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    hmm but if my tranny fluid was leaking would it cause the milky build up?
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    Could even be the coolant pellets that you are supposed to put in the radiator everytime you change the coolant. I stopped using them because it makes the coolant look like it has rust in it.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    i dont use the pellets.
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    If its look like a strawberry juice its your radiator tish it self internally.but if its look like a iced coffe your inlet gaskets needs to be renewed.
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    yeah its a coffe looking colour, have contacted steve at MACE about a gasket set.
  1. Brown slime on my radiator cap
    By Killr6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-11-2011, 12:55 PM
  2. Brown Slime in top of v6 radiator
    By JoshSvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2009, 11:40 PM
  3. milky slime in top of motor
    By peeingeye in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2009, 06:01 PM
  4. brown crap in radiator
    By Simonn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2009, 05:41 PM
  5. brown slime in my radiator!
    By Fully in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2006, 06:05 PM
