Results 1 to 18 of 18
Thread: High Idle - sometimes
    VX Commodore Executive
    Jun 2011
    Central Coast
    Default High Idle - sometimes
    I recently had my VX Series II (V6) converted to LPG dual fuel, using a second hand Impco system.
    Since installation the car idles at various rpm, sometimes 750 RPM, sometimes 1100 RPM, and most commonly, 1250 RPM.
    He mechanic said the car has a “sticky throttle”, but couldn’t figure out why. He suggested changing the Oxygen Sensors, which I did, as well as the spark plugs and leads.
    But the car is still doing this.
    It only does it when running on gas.
    Sometimes when I rev it tio around 3000 RPM (on gas) it then settles down to 750 RPM.
    Other times I have to switch it to petrol then rev it then switch back to LPG to get it to settle.
    But sometimes nothing works.
    Anyone have any idea what else I should check for/change?
    Cheers,
    JG
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    A sticky throttle could be due to a build up of crud in the throttle body where the butterfly opens, that would cause high idle. I would be checking the IAC (Idle Air Control Valve) and giving that a good clean.
    I'm assuming that the 70RPM is a typo because it would stall at that.
    MY RIDE
    Jun 2011
    Central Coast
    Thanks for the quick reply.
    Quote Originally Posted by accentstencil View Post
    Yes, that was a typo. I have edited the post to say 750 RPM.
    Also added that it only does this on LPG.
    Where would I find the butterfly?
    Cheers,
    JG
    VY SS
    May 2011
    Auckland
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by jughead1 View Post
    Cheers,
    JG
    If you take of the big pipe that goes from the throttle body to the air box you will see the part that opens and closes when you accelerate, that is what I mean by butterfly, it may not be called that but in a carby it is.
    MY RIDE
    Jun 2011
    Central Coast
    That is what I thought you meant. But if that was the problem, I would have expected the car to behave the same way when running either LPG or petrol.
    It does not do that when running on petrol, and only started after the LPG was installed, so I suspect it is something to do with the LPG system, but buggered if I know what!!
    JG
    EVIL304
    Oct 2011
    Jun 2011
    Central Coast
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I was referring to the butterfly for the sticky throttle which your mechanic mentioned.
    For the erratic idle I would still check and clean the IAC valve. Although I don't know anything at all about LPG and if the IAC is used when switched to LPG
    MY RIDE
    EVIL304
    Oct 2011
    Lake Edge motors at Tumbi Umbi (on the Central Coast of NSW).
    The reason i ask is what were the conditions on installing the secound hand LPG ? was the car running fine when you handed the keys to the mechanic ?
    Jun 2011
    Central Coast
    Quote Originally Posted by 5LVTSS View Post
    The car was running fine, but the mech did say there is no warranty on the equipment itself - just on the install.
    He spent an extra day trying to get the system to work correctly, and was very pissed off that it was nopt working as it should.
    He did mention that the system was not up to his standard (I bought it on ebay from a guy in melbourne).
    Unfortunately at the time (and still now) I did not have the money to get a new system installed. So this was the best I could do.
    JG
    EVIL304
    Oct 2011
    JG
    Thats a hard one mate maybe cut your losses and take it off if it isn't easily fixed.
    Jun 2011
    Central Coast
    The car is running fine, even with the un-even idle. It is just running a little less economically than expected. But it is still cheaper than running it on petrol. I drive around 850 KMs a week, so it makes a big difference.
    Thanks for all the replies.
    Cheers,
    JG
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    Ask the installer if he changed the memcal because if he didnt then u may need a tune setup for LPG
  15. #15
    EVIL304
    Oct 2011
    Quote Originally Posted by xcler8 View Post
    Xcler8 makes a good point have it checked out.
  16. #16
    Jun 2011
    Central Coast
    Ghost's Avatar
    Sep 2011
    The memcal is inside your ecu the memcal is made up of settings that control the engine and sensors and gearbox as well
  18. #18
    Jun 2011
    Central Coast
    Ah, OK. It is the computer chip?
    Would that cause the idle to change from 750 to 1000 to 1250 RPM at various times?
    Also, is there a sensor that tells the engine the temp, so it will idle high till the engine is warm, then reduce the idle?
    (Although I don't know why the idle would be normal in petrol but not in LPG.)
    Cheers,
    JG
  1. vy ls1 high idle!! please help.
    By victor71 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-02-2011, 02:40 PM
  2. New T/B high idle
    By briby in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-01-2011, 06:51 PM
  3. VS V6 High Idle
    By alipete in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2008, 12:43 PM
  4. High Idle
    By VStooDie4 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-03-2006, 10:33 PM
  5. High Idle
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2004, 12:58 PM
