+ Reply to Thread
Results 1 to 20 of 20
Thread: how enable hidden mode on 99 vt cluster also is a super charger worth it/////////////
    99vtwgn Guest
    Default how enable hidden mode on 99 vt cluster also is a super charger worth it/////////////
    how 2 enable hidden mode on a vt cluster
    VT V6 twin Turbo
    Feb 2005
    Newcastle region
    Quote Originally Posted by 99vtwgn
    hold mode up is 1 and mode down with the ignition on release buttons this is on a calais aldepends on what charger you wan't
    ZER0 Guest
    well it depends what you meen by hidden mode, if you mean digital speedo you need to get your holden dealer to enable it (there is hunderds of threads about this)
    secondly (despite there is also hunderds of threads on this too) supercharging what il assume is a stock V6 is a very costly process, to do it properly and take full advantage of the modification the cost will often out way the cost of the car.... its not as sipmle as just bolting it on.
    so short answer, if you have about 7 grand laying around go for it!
    Balistic3.8L Guest
    Quote Originally Posted by ZER0
    You dont need to take it to holden to get a digital readout of your speedo man.you can get heaps of stuff of the hidden menu and it wont cost you a cent i use it all the time including the digital speedo and taco .voltage.amps.fuel temp.reset service interviles.heaps of stuff i posted a thread on this months ago look for it in v6 dev and mods its to ez dudes cyas
    ZER0 Guest
    but i do belive you need to go to holden to have it load up digital as standard every time you start the car, insted of turning it on every time you want it
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    ok, i might be taking a stab in dark but the mode and down menu looks like it has a function to calibrate the speedo and stuff like that due to diff changes, wheel size changes ect
    Check out My SV8 One Tonner
    You can get a lot farther with a kind word and a gun than a kind word alone
    minux's Avatar
    minux is offline Infidel Bear minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    CAPA Powerdyne to suit LS1, $4k for everything you need to fit, will bring rwkw upto about 270-280
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN justbad4you Berlina
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    i saw this add a few weeks ago and wondered why no one put in a bid for this supercharged wreck on ebay...take a look at this add and ask the guy if he still has the supercharged wreck for sale>>>>>>http://cgi.ebay.com.au/VT-Supercharg...QQcmdZViewItem this would be you best bet...get a supercharged wreck like the one in the add and change over everything into your eng bay...its all there take a look......cheeers
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    Nissan Pathfinder
    Sep 2005
    Quote Originally Posted by Balistic3.8L
    couldnt find it dude,
    anymore info would be cool, cheers
    VTII R8
    May 2005
    when car is off hold mode and up, turn car on keep holding them, let car run for a second for good measure, then release them and you get a lovely noise and the extra functions. If you want to get rid of it mid trip pres up and down at the same time.
    Nissan Pathfinder
    Sep 2005
    Sep 2005
    when you enable the extra modes? do you loose the other one that are standerd? or do you get them all...........thanks in advance .........cheers,,,,,,,,,,,,,
    throttlehappy Guest
    throttlehappy Guest
  15. #15
    Sep 2005
    no i dont think it can be done on the older commies..ask dr bob or ratattack thay willl know for sure,,,,,,,,,,,,cheers and good luck
  16. #16
    VTII R8
    May 2005
    I think there is something in the other threads for a VS. I am not sure about a VR. And no, you get a new set of functions, to get the old ones back you have to go back to normal mode. Also you do get the electronic speedo in the extra functions.
  17. #17
    VT V6 twin Turbo
    Feb 2005
    Newcastle region
    Quote Originally Posted by Zharklm
    my vn calais had the function for digital speedo
  18. #18
    throttlehappy Guest
    Quote Originally Posted by cuckoo
    so what exactly does it give you
    my trip comp gives me 9 functions i think
    fuel inst, fuel used, fuel average, distance traveled, trip time, ave speed, odo, others i cant remember.
    what would it give me if i changed it?
  19. #19
    throttlehappy Guest
    Quote Originally Posted by throttlehappy
    wouldnt mind trying it but would like to know beforehand
  20. #20
    VTII R8
    May 2005
    Just give it a go, if you dont like it either press up and down or turn the car off and you are back to normal
+ Reply to Thread
  1. Super Charger for V6
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2006, 10:59 AM
  2. Super charger
    By Sensations in forum The Pub
    Last Post: 15-02-2006, 03:29 PM
  3. super charger ....... possible?
    By pheonix in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-10-2005, 09:56 PM
  4. Super Charger Whistle
    By blue alliance in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-07-2005, 12:36 AM
  5. Little Jap Super Charger
    By freckly in forum General
    Last Post: 11-02-2004, 06:09 PM
