I am replacing the rear map pocket of the front passenger seat, and have bought the complete panel (plastic) with the map pocket attached, how do I remove the old one and replace it with the new one. Got a shock when I went to a Holden dealer who wanted over a hundred dollars for just the map pocket, when I bought the rear plastic panel complete with map pocket for $60 from a commodore wrecker. Any help appreciated.![]()
OK, you will need to go to holden and get 2 of the clips that hold panel to the bottom of the seat back.
Basic procedure is as follows (may not be 100%, memory is a bit foggy)
1. grab panel at bottom. Lift and pull, whilst sitting in back seat, with a bit of force. You will break these clips (hence you will need replacements).
2. when clips are broken, pull panel down and out. fit new clips to new seat panel, install is reversal of removal.
