Results 1 to 22 of 22
Like Tree1Likes
  • 1 Post By accentstencil
Thread: fuel filters
    troykinsvt's Avatar
    troykinsvt is offline yes i like fibreglassing
    VT
    Oct 2011
    helensvale
    Default fuel filters
    so im gonna change my fuel filter and im wondering if its possible to get an electronic fuel filter
    or regulator for a vt ecotec ?
    along side a cam angle sensor, crank angle sensor spark plugs and oil filter .
    any input is helpfull
    stroking is fine but id rather be blown
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    Quote Originally Posted by troykinsvt View Post
    Electronic fuel filter? Wah???? Please explain????
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I googled electronic fuel filter and came up with nothing, as I suspected, there is no such thing.
    MY RIDE
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Go to Repco. "I need a fuel filter for a VT".. done.
    Crank angle sensor... why? Do you have ignition issues?
    Oil filter.. If your changing the oil.. Part Numb is Z154
    Spark plugs.. Inspect them first but if its been a long time since they've been done then may as well.
    showbags's Avatar
    VT Calais,F6E
    Dec 2009
    Quote Originally Posted by accentstencil View Post
    Thought it must of been some fully sik bro logic filter.
    troykinsvt's Avatar
    VT
    Oct 2011
    helensvale
    the vt is having those stalling issues , on hot days comin to lights... yada yada yad blah blah , you know the rest ,so fuel filter is first on my mind,
    was wondering if there was an eletric fuel filter... anyhow seems theres not,
    im guessing a electronic fuel regulator is different :/ ,
    the cam sensor change due to it stalling, and possibly crank angle sensor too
    spark plugs cause i dont think they have been changed
    and the leads ...may as well
    the car has 180xxx ks so its time to change
    troykinsvt's Avatar
    VT
    Oct 2011
    helensvale
    autobahn has an eletric fuel regulator for an s13 , wasnt sure if they meant filter ....
    showbags's Avatar
    VT Calais,F6E
    Dec 2009
    Crank angle sensor- either works or doesn't. Regardless of weather conditions.
    Cam angle sensor- only control sequential injector pulse. Will not effect the way a car runs.
    Fuel pressure regulator- wont cause it to cut out on a hot day.
    If your dash light come on and then it cuts out, change
    Your battery terminals and earth leads.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Check your fault codes to see if there are any codes related to the cam and crank angle sensors, no point in replacing them if they aren't faulty.
    MY RIDE
    troykinsvt's Avatar
    VT
    Oct 2011
    helensvale
    canister purge came up as a code and i dont have an air box so that sensor came up, i can drive for hours without stalling but on shit days when traffic is backed up it dies then starts 3 mins later...dash lights up, battery light and all come on, revs drop to 500 and bounces to 700 and then dies...
    troykinsvt's Avatar
    VT
    Oct 2011
    helensvale
    Quote Originally Posted by showbags View Post
    how do i change the terminals and earths ???
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    My daughter's VR kept breaking down when hot, replaced the CAS (there was a fault code for the CAS) and it still kept happening. I then replaced the fuel pump and it hasn't stalled since. One possibility.
    MY RIDE
    troykinsvt's Avatar
    VT
    Oct 2011
    helensvale
    fuel filter tomoz then, how do i stop the fuel coming out so i can change it ?
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    Same with my mate simmo's VQ Stato, fuel pump solved that issue for him.
  15. #15
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    First de-pressurise the system by removing the fuel pump fuse and starting the engine, it will run for a few seconds and stall, then turn the engine over for about another 5 seconds (it won't start).
    There will still be a little bit of fuel in the filter so watch your face.
    Because the filter is up higher than the tank petrol won't keep flowing out.
    MY RIDE
  16. #16
    troykinsvt's Avatar
    VT
    Oct 2011
    helensvale
    thanks accentstencil is the fuel filter fuse in the engine bay or under dash ?
  17. #17
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The fuel pump fuse is in the engine bay. To release the fuel lines from the filter, push the black plastic bit towards the filter, then squeeze the tabs on that plastic bit, then pull the fuel line off, hard.
    MY RIDE
  18. #18
    troykinsvt's Avatar
    VT
    Oct 2011
    helensvale
  19. #19
    vx commodore
    Feb 2012
    darling downs
    does the system need to be bled after running out? Or just replace fuse and away we go?
  20. #20
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by FreshVX View Post
    Just replace the fuse and turn it over, it might not start first go but it probably will.
    MY RIDE
  21. #21
    VY S V6 Ute Series II 2004
    Nov 2009
    The only symptom a blocked fuel filter shows is that the car will not go fast. Other than that it will run fine.
  22. #22
    troykinsvt's Avatar
    VT
    Oct 2011
    helensvale
    Lock/delete please mods
  1. performance fuel filters?
    By nathanVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2010, 10:25 PM
  2. Pod filters onto tb, less power but more fuel economy?
    By nathanVY in forum V6 Development And Modification
    Last Post: 03-03-2010, 01:51 PM
  3. VS and VT Fuel filters - are they the same???
    By majac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2010, 06:18 PM
  4. What oil & fuel filters do you use?
    By Charg'd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2007, 08:13 PM
  5. Fuel filters
    By sexcvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2006, 08:20 PM
