Results 1 to 8 of 8
Thread: temp gauge in my vt is faulty
    98 vt executive 9c1
    Jan 2012
    Harden Nsw
    Default temp gauge in my vt is faulty
    hey all.. unsure if this has been covered but couldnt find anything in the search but any way, i flushed my radiator the other day and now my temp gauge is playing up. when the car isnt running its right at the bottom but when i first start the car in the morning it jumps up to just below the first line. what is the problem, it was fine before i flushed it?...
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    maybe need to change your temp sensor its just under your thermostat housing
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    Have you bled the cooling system properly? The temp gauge wasn't working on my VS and I found out it was because there was still air in the system. The temp sender only works if its covered in coolant.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    98 vt executive 9c1
    Jan 2012
    Harden Nsw
    unsure if i did it properly.... i took the top hose off the radiator and the bottom.. ran the water through the top till it came out the bottom clean.... then took the thermostat out and ran it through there till it came out clean. then put it all back together... started the car and ran the heater and filled it up till it was full. same with the resivior.... now im finding that ive gotta put water in more often.. never had to before this..
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    sounds like u havent bled the system yet and u may have air trapped in the lines somewhere so bled the system 1st and see how u go. make sure u keep the heater on while doing this aswell.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    98 vt executive 9c1
    Jan 2012
    Harden Nsw
    wrx884's Avatar
    Mar 2006
    on top of the thermostat housing theres a bleed screw, run the car 4 about 10mins 2 build the pressure up and then unscrew the beeld screw until u hear air escaping, close and open it a couple times if need b, coolent will spit out at a constant flow after all air is out then just tighten up the screw again.
    98 vt executive 9c1
    Jan 2012
    Harden Nsw
    too easy.. thanks mate.. ill go do it now
  1. vn calais fuel gauge/temp gauge cluster voltage board
    By JuZo!!! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2011, 01:19 AM
  2. oil temp/water temp gauge wiring
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-05-2011, 04:53 PM
  3. temp gauge an fuel gauge not working
    By nathan_867 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2010, 10:55 PM
  4. normal running temp for a VT 5L? and temp gauge..
    By mike49 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 12:57 AM
  5. Temperature Gauge Faulty
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2006, 06:04 PM
