Results 1 to 21 of 21
Like Tree2Likes
  • 2 Post By Clutchy
Thread: VE engine in a VT
    97+98VT 3.8 Wagon and a 1995 VS Commodore Wagon 3.
    Mar 2011
    Coffs Harbour
    Default VE engine in a VT
    Hi
    My VT commodore has a blown head gasket and I have to get a new engine.
    My question is does a VE engine fit into my VT engine bay?
    Or can I put in a V6 SuperCharge engine in?
    What is involved and what other parts do I have to change to fix the problem?
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    It would be heaps cheaper and heaps easier just to fit a L67 (supercharged V6). It wouldn't be worth the effort to try and fit a VE V6 plus all the modifications, and the ECU and BCM wont connect to each other.
    L67, just bolts straight in, just have to change the wiring loom and ECU (maybe the BCM) which isn't a big job.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    It can be done. But it an expensive exercise. It'll cost you about the same as an LS3 conversion.
    VT manual/ VL turbo manual
    Feb 2012
    Kingaroy
    Y is it so costly??? dose anyone know what is involved and has anyone done the conversion???
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Quote Originally Posted by ismasiv View Post
    You would have to make up brackets for the engine mounts, (because VT's never came out with Alloytec V6's, there wont be a K Frame to suit), transmission will have to be changed as the bell housing would probably be different, ECU and BCM (not sure what would have to be done there), wiring loom/s will be different. I am pretty sure that the diff ratios are different so it wont feel the same to drive i'd say.
    Not sure what else but pretty sure there would be more.
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Because you're trying to fuse two incompatible cars together?
    Just get an Ecotec for it, will be so much cheaper and arguably better. If you must have more power *Tim Taylor grunt* just whack a V8 in there.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    Commodore M6
    Jul 2010
    East Coast
    the VE V6 is a pile of garbage anyway... i would imagine you could spend more than $5k paying someone to get this done and its still crap
    showbags's Avatar
    VT Calais,F6E
    Dec 2009
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by maurso View Post
    Hi
    Alloytec conversion will cost more than it will be worth.
    Super6 or just put another V6 in there.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Not that incompatible as the VZ had basically the same V6 as the VE.
    As said it would be an expensive exercise though, complete wiring loom, ECU, BCM etc.
    Definately go the super6, more power potential and much easier/cheaper.
    Silver Certified.
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    If you really wanted to, you could buy a VE Commodore, take all the panels off and replace them with you VT panels, and swap interiors. But there will be a few gaps around the car, and you would look like a tool driving it on public roads.
    You have have listed two options:
    1. My question is does a VE engine fit into my VT engine bay?
    2. Or can I put in a V6 SuperCharge engine in?
    Answer to number one: Don't bother, it would probably fit but you would have to make too many modifications and it will need an engineers report.
    Answer to number two: Yes you can put a supercharged V6 in, it will be the easiest option and you wont have to change K Frame or anything like that. Or you could get the V8, swap the K Frame and whatever else you need to swap to fit the V8.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    couldn't you use a VZ alloytec, vz K-frame, vz box, vz wiring and the rest? Theoretically it would all bolt in but I can't see the point to be honest, just go with the L67 or V8.
    ========My Statesman 20's Mafless and 3.9's========
    showbags's Avatar
    VT Calais,F6E
    Dec 2009
    Quote Originally Posted by ucwepn View Post
    VZ ECU & VT BCM won't talk to each other. You need to use aftermarket management.
    njmartin is offline Banned
    VR exec, VY wagz
    Nov 2011
    S.E Melb
    vz wagon
    Aug 2006
    Wild west of Melb
  16. #16
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Quote Originally Posted by Clutchy View Post
    Why can't ya just put new head gaskets on ya current engine ?
    Farkin genius work there!!!!
    Unless he cooked the engine lol but still genius
  17. #17
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    How do you know its a head gasket? Milky coolant isnt always a head gasket.
    Silver Certified.
  18. #18
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    You could use a VZ K frame to support a VE motor. Wiring and computer you could change over yourself you would have to ask Holden if they would be able to link a VT BCM and a VE ECU.
    Or for a shit load less money and effort you could buy a gasket set off eBay for less than 200 bucks and fix your motor.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
  19. #19
    1979 Commodore 3.3 sedan, 2001 VX Commodore Equipe
    Aug 2009
    Orange NSW
    Latter idea is the best - fix the head gasket (if that is what the issue is). If you can do the work yourself, maybe $500 tops. What mileage on your engine? A reco exchange may also be a sensible option. IMHO for day-to-day driving standard ecotec V6 has enough oomph; supercharging/V8s may only work if you intend to race it.
  20. #20
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Just toss the old VT and buy a VE their going for about $10,000 now! Lol
  21. #21
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by scvs6 View Post
    You could bolt in a VY/VZ alloytech Kframe, its all the same chassis VT-VX-VX-VY
    I personally wouldnt bother, you have to fit the PCM(powertrain control module, tune it for the gearbox or fit the VE gearbox), Make the looms mate together nicely and all for a loss in capacity and "spark injection"
    the L67 is a good choice, the ECU is actually the same as the N/A V6 just the EPROM is different however you can source a HSV XU6 Tune or even a std S/C one easily, it uses a 27C010 32pin EPROM. Just make sure you get the injectors etc you'll need to fit a bigger fuel pump too.
    Given they used this engine upto about 2003-2004 you should beable to get a create motor still, last check it was about $5000 for a brand spanker. (more than likley bare block)
  1. vx coughing and spluttering after v6 engine swap with wrong engine
    By bogan_vk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2011, 08:11 PM
  2. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  3. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  4. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
