Results 1 to 13 of 13
Thread: what type of cam
    vx ss
    Feb 2012
    kojonup
    Default what type of cam
    what type and what brand of cam is the best for daily driving for my ls1
    Jan 2008
    NSW
    Choose any cam you want, Its all in the tune. My cousins senator has a pretty big cam, shaved heads, 4k stall, 4.11s makes 350rwkw. Drives it everyday without any issues. Ive driven it a fair few times and the only difference I find from stock is the SICK idle brrb brrb brrb lol and the car kinda rocks from side to side slightly.
    Small cams are for pussies!!!
    vx ss
    Feb 2012
    kojonup
    is it an ls1 if has he had troble with his rear main iv heard thay pop in the ls1 with pressure?
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Just my 2c... BRANDS:- Comp CAMS, CRANE, ISKY, C.O.M.E(AUS), CROW, Camtech, Howards, Manley etc. etc. etc.... and the list goes on and on and on and on...
    Camshafts are a very personal choice that should meet your driving style, daily or weekend driver, performance over economy/durability and coupled with all the other mods can produce huge increase in grunt.
    Tuned VX SS
    Jun 2010
    No one will be able to give you a solid answer on your question without more details. It all comes down to what you want out of the car.
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    talk to the company/person you choose to install it about your needs, most will be competent enough to give you what you need.
    VZ SS
    Jan 2011
    u have already got the 3.9s so you might as well use them to your advantage and go big and lumpy. Let the blue beast just scream
    vx ss
    Feb 2012
    kojonup
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    thats easy just pick a cam that will also suit a supercharger .. i think with a supercharger you want more lift and less overlap (someone correct me if im wrong) ... ive got a .600" lift cam in my vx ss with 112deg sepperation it still sounds lumpy as f*ck and it will still be fine when i put a PD supercharger on it.
    If in doubt......FLOOR IT!!!
    vx ss
    Feb 2012
    kojonup
    But with a real lumpy cam my fuel will go tho the roof wot does ur vx make??
    Mar 2011
    roxby downs
    310rwkw thats with cam 238/240 .605" 112deg (biggest lift i could fit, got less then 1mm clearance between valve and piston), oversized valves and heavly ported heads, VE 100mm maf intake... fuel consumption isnt as bad as i thought it would be i had a VP V6 when i was on my p's and it uses the same fuel as that thing haha
    vx ss
    Feb 2012
    kojonup
    how much can you get of a tank i had a vp before this and i could only get 350 klms off a tank
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    thats the km's you'll probably get with a cam of that size.
    If picking a cam for a SC look for more duration and lift on the exhaust side compared to the intake as the air will be forced into the intake and you want it to get it out as fast as possible
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
  1. best oil type and coolant type for vl rb30 n/a???????
    By rb30vlsl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-01-2012, 07:46 AM
  2. Coolant? Type A or Type B
    By phuecn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2010, 07:26 AM
  3. Oil Type
    By edals in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2009, 06:45 AM
  4. F.I.T Type S CAI Anyone????
    By holdenvx38 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-05-2008, 08:57 PM
  5. What Type Of Sub Do I Go For
    By Dave398 in forum Car Audio
    Last Post: 21-11-2005, 05:44 PM
