Results 1 to 20 of 20
Like Tree3Likes
  • 2 Post By Reaper
  • 1 Post By Rano11
Thread: Alloytec heads on a ecotec bottomend
    VT manual/ VL turbo manual
    Feb 2012
    Kingaroy
    Wink Alloytec heads on a ecotec bottomend
    Hi guys I have just bought my first holden after having many many great fords.....lol I have a VT Spack 5speed and i'm pretty happy with it. i have replaced alot of parts like the heater core and exhaust and other things like that... now getting back to the point that I want some power.. I have got some parts already
    Pacmakers and a 2.5" exhaust
    lightened flywheel and clutch kit from exedy
    Ported T/B
    can the Alloytec heads bolt on to a ecotec bottom???
    NOW I would like to do 3:5 diff gears and a LSD
    I need to replace the head gaskets so was also thinking of getting 15thou taken off and getting the ACL 1mm thinner head gasket
    I would like to do a stage 2 cam and chip but would also think about the 1.98 rolla rockers
    and is there any difference with the air boxs and pipes between the V6 and SS or any other models out there??
    I just want to do some small things like that just to give it abit more go if I don't do any of that I will just supercharge it with the 1.98 rolla rocker and the 11psi pully upgrade... but keep in mind its just got the Getrag gearbox... any pointers and help would be awsome.......
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    The heads are not interchangable. Plus on the ecotec, the spark plugs are located in the side of the heads, with the alloytec, they are located in the top of the head. Ecotecs use Spark Plug leads and coils, Alloytecs just use coils. But mainly they wont fit different engine completely.
    Whats with people starting to ask questions about Alloytec engines/heads in pre-VZ Commodores?
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    Commodore M6
    Jul 2010
    East Coast
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Five cams for that awesome hecticness.
    Ronald Reagan (1986)
    Feb 2012
    Kingaroy
    ok so i cant put the alloy tec heads wont fit on the ecotec bottom end so what is every ones thought on the rest????? thanks TonyJZX for all you help and wise words u fuc head... I don't know any thing about holdens this is Y i ask....
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    Sad to see how many need to ridicule those whom dare to ask questions.
    As a direct bolt on, No, they wont fit, I haven't had a set of each heads next to each other to compare how differently all the water jackets and ports etc line up. If you have a set laying around, compare them and ask a machining/engineering shop if it's remotely possible if most of it lines up. Mind you, the cost would make it not worth doing seeing as you'll gain very little per $.
    All your little mods aren't really worth doing if you can hold off for a little longer and then put the blower on it.
    LSD and better ratio to suit your driving is always worth doing.
    Forced induction prefers a lower compression setup than a higher compression setup so supercharging it after decking the heads would be a stupid thing to do. Same as thinner gasket, you want better gaskets to handle forced induction not thinner.
    So bang for buck, forced induction. If not, the above mods bit by bit will be counter productive to what you want to have in place if you supercharge it later.
    Roller rockers are always worth having.
    Cam choice should be mated to a firm decision now whether you're putting the blower on or not. No point doing a stage 2 cam now and then finding it doesn't like being combined with a blower. Choose a cam suited to your application, or wind up doing the cam again later.
    You wont achieve as much with the little mods as you would with the blower, but some of your mods aren't a wise choice to have done if you do supercharge it later.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    I think the stand out reason would be that Alloytec are OHC and ecotec is single cam.
    In a practical sense, it's completely impossible.
    Quote Originally Posted by TonyJZX View Post
    lol
    this thread takes the cake
    Quote Originally Posted by acarmody View Post
    So the two of you where born with all your car knowledge? Never had to learn through asking a stupid question or two?
    1998 VT Commodore
    Jan 2012
    Heathcote
    If I were you, I'd get a 2nd hand set of heads in good condition, and then build them up to spec, to handle your supercharger if/when you get it. Then you can port/polish them, get them machined, valve job etc and then when it's time to supercharge, take the other heads off(and rebuild them, so you have a spare just in case lol), put the new ones on, do the gaskets and shit all at the same time. That way you still have a car to drive, instead of having none for the week or so that it'll take to get it all set up and running.
    I'm sure there is a way to get the alloytec heads to work on the ecotec, but it'd be a royal pain in the arse, would need a fair amount of stuff added to the VT block to support the head and all the (presumably) different water jackets(would involve a 1" thick piece of steel, with the ports for the vt block on the bottom of it and then mating it to the alloytec at the top with the ports up there, and in between the top and the bottom changing the direction it goes...effectively increasing the displacement of the engine, requiring 2 head gaskets, longer conrods(probably not possible) or higher pistons, etc. Then you'd need a way to get the cams moving in the head...and a way to bolt it to the block and also bolt the head to the adaptor bit and the block...not sure what the cam system is like in it, but you'd probably need a way to get some motion from the crank up to the head to turn the cams...
    As you can see, it isn't going to be easy...try it if you dare lol
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Not going to be easy? Not going to be possible. Why would you even waste time attempting to try it when it clearly wont work. Read the posts that say what is different like the cams (in the head on the Alloytec, in the block on the ecotec), spark plugs (different locations on the heads), water jackets. Not to mention that the blocks are different. If you have a look at the heads, they are also a different shape, so the inlet manifold wont fit.
    If you want to keep the V6, you would be better off going L67, or putting L67 heads/inlet manifold on your ecotec engine (not sure how long it would last).
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Just to throw this into the mix, before all the haters jump on board....
    Why are you sticking with the 6? For the amount of money you're looking to throw at this you could get a 5L or even an LS1 and start the modification process on that. You would come out MILES ahead financially and on a power basis.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VY SS
    May 2011
    Auckland
    Quote Originally Posted by scvs6 View Post
    Any things possible with enough money. how feel are your pockets?
    Would be worth planning what you want to do from the start rather than doing mods you'll then have to remove at a later date.
    If you want an alloytec (ohc 6) why not just swap the block as well? Would be much less work.
    1998 VT Commodore
    Jan 2012
    Heathcote
    If we can get man to the moon, I'm sure it will be possible. Impractical, stupidly expensive, but it'd at least be doable. For shits and giggles, of course. You'd end up adding 10kg to the finished weight of the motor and definitely voiding any warranty.
    I mean, humans manage to keep human babies alive with no brain(literally)...
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by Irukanji View Post
    Lol - fail thread for something that will never happen. About the only way your going to get an Alloytec head to fit a Ecotec is to melt it down and cast it into the ecotec design.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  15. #15
    1998 VT Commodore
    Jan 2012
    Heathcote
    Reaper
    I gave a perfectly workable way to get the heads on, and still at least get compression and the first spark...after that you'll have to hope it doesn't explode.
    Then again, why doesn't OP just get an alloytec block with the heads and remove all the hassle? Or sell it and buy a VZ...or use the search feature.
  16. #16
    Sabbath''s Avatar
    Jul 2006
    This i've got to hear more about...
  17. #17
    holden vx executive s2 vx v6
    Feb 2010
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Quote Originally Posted by Rano11 View Post
    just get a fuc##n V8 pointless spending on a six !
    Yeah let's all buy v8's and do the same mods and be full hectic together
  19. #19
    1998 VT Commodore
    Jan 2012
    Heathcote
    Quote Originally Posted by Cameron P View Post
    Rofl, be fully sik ####z
  20. #20
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    I wish I was! But I drive a v6 that I shouldn't modify cause v8's are the only thing worth spending money on
    =P
  1. ecotec heads
    By lvljones in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2011, 02:31 PM
  2. [NSW] FS: Vs ecotec heads
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 20-01-2011, 08:40 PM
  3. FS - Ecotec heads
    By muvro in forum Parts And Other Items For Sale
    Last Post: 22-10-2007, 05:57 PM
  4. vx ecotec heads on vr v6
    By race in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-06-2005, 09:48 PM
