Results 1 to 10 of 10
Thread: Massive oil leak!!!! Please help!
    VX Commodore Wagon (stock)
    Feb 2012
    Default Massive oil leak!!!! Please help!
    Hey guys,
    I just got a VX Commodore wagon. I spent $800 today buying new stuff oil, coolant spark plugs etc. when i jacked the car up i noticed a large amount of oil start leaking from what looked like just behind the lowest (large) pulley, or the gasket above the Oil sump. has anyone else had this? Is this possible for me to fix myself or does it need to go to a mechanic?
    thanks for your thoughts.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The actual seal is easy to replace but the bolt for the harmonic balancer can be a pain to undo (plenty of threads with tips on how to undo the bolt) and you will need a puller to get the harmonic balancer off. It's called the front main seal, I think.
    MY RIDE
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Socket on the bolt, extension on the socket, bar on the extension under the chassis rail, kick the starter over gradually with the key until it loosens the bolt.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    pressure clean the front of the engine and recheck after a couple of days to confirm oil leak from either timing case seal or sump gasket or both
    strgas's Avatar
    Oct 2009
    Quote Originally Posted by Sabbath' View Post
    disconnect injectors so that engine does not fire and continues to run .
    Feb 2012
    Thanks for the help guys that doesn't sound sooo bad lol. I just sold my r33 skyline Friday night and did most of the servicing on that so I should be able to do this... Does anyone have a link to this tread that explains how to do it??? That would be much appreciated!!!
    ClairBear's Avatar
    ClairBear is offline Make the stupid stop!
    VE Omega / Hyundai Getz
    Nov 2003
    SA - The Murder State
    There are lots of threads, just use the search function top right of your screen.
    Hope you get it sorted.
    Quote Originally Posted by commodore1310 View Post
    Ok, once again ive run aground with a bunch of elitist PRATS who think they know it all, stuff your cars and stuff your forum!
    Quote Originally Posted by one_and_only2004 View Post
    No, driving a v6 engages GOD MODE. Please don't continue the argument...
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by STOCK1 View Post
    You should get hold of a workshop manual for your car. The stuff you want to know is explained, step by step, with plenty of pics or diagrams, you cant go wrong. Gregorys workshop manuals are pretty good.. These manuals are well worth the money and can save you a fortune if you do your own work on your car.
    vx executive series II 3.8 ecotec
    Feb 2012
    sippy downs
    ide take it to a mechanic anyways just to be safe
  1. Massive Vp Leak
    By COMMY VP 666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2010, 05:34 PM
  2. i have a massive problem... anyone know how to fix it?
    By Gurezy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-11-2009, 10:27 AM
  3. Massive oil leak
    By caekmaster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2009, 09:19 AM
  4. Massive injector leak!:)
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2007, 10:25 PM
  5. Massive Grommit!
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2006, 05:14 PM
