What wood that be?
could be alternator or bad battery connections.
I was driving at 65 wen the abs flashed no and off then my cd player stoped and all the gages stoped working then lost most of the power to the engine it just got me home
Sounds like your alternator isn't charging your battery properly. I would sus that out then go from there.
How can I test that
Get a multimeter and see how many volts there is when the vehicle is on.
Is your battery light on as well. A similar thing happened to me the other day, A/C turned off, gauges stopped working, ABS and traction off lights came on, but no loss of engine power, so I measured the voltage and it was 14.2 v at idle (at which point the battery light turned off) but when I revved it slightly it went up to over 15 volts. I didn't rev it too much because of the huge increase in voltage. I bought a new alternator and it's fine now. I could have just changed the voltage regulator but with the LS1 alternator the regulator is internal, unlike the V6 which can be easily changed. Besides the alternator is right at the bottom of the LS1 and a real pain to remove, it was covered in grease and crap so I thought why not just get a new one.
MY RIDE
No the battery light has never cum on wen running b 4
