Results 1 to 2 of 2
Thread: Rear RH Passenger Door leaking into interior
    VXII Berlina 3.8L
    Oct 2005
    Default Rear RH Passenger Door leaking into interior
    Hi All,
    The mastic (yellow resin) that holds the water deflector in place between the sheet metal and interior trim on the car doors (VX Berlina) has given way on the rear RH passenger door at the bottom and water leaks into the car now. I've tried to find out who sells this stuff in Newcastle to fix the leak but have only had success with one of the local Holden dealerships. The only problem is that it only comes in a 12 metre roll which is enough to do about 40 cars. I don't need that much of it.
    Does anyone know if this stuff is sold in Newcastle in smaller quantities? Any recommendations on a substitute material that has the same properties?
    Thanks,
    1979 Commodore 3.3 sedan, 2001 VX Commodore Equipe
    Aug 2009
    Orange NSW
    RACING TAPE!! Had exact same issue, used racing tape (aka duct tape, gaffer tape), when door card was back on trimmed off excess tape carefully with a scalpel. Leaking appears to have stopped. Hope this helps
  1. leaking water in the front by passenger door, any common leaks there
    By controlled chaos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2012, 02:37 PM
  2. Top of Rear Passenger side leaking Leaking
    By Holden=#1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-10-2010, 10:23 AM
  3. Rear passenger door solenoid
    By graham7773 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-06-2010, 05:02 PM
  4. Rear passenger door not locking
    By Jxarm in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-03-2007, 12:28 AM
