Results 1 to 6 of 6
Thread: Hose under inlet
    VX S2 S Pack
    Dec 2009
    Default Hose under inlet
    Im just wondering, what isthe little black hose that attaches just under where the hose from the air filter attaches, does that also let air in or out? im trying to find out what us making an airy sound from under my bonnet, i checked the air filter, gave it a clean, made sure it was fitted properley. That little black hose clamp is a little lose not sure if i should try and tighten it or not, where else would air be going through, any pictures would be a great help as i dont know much about motors. Im also going to be getting a new fan belt as this one looks like its on it way out, and my gasket just above the spark plugs seems to have a slight leak should get them done aswell.
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Quote Originally Posted by TOMCAT85 View Post
    pictures would be a great help.
    10words
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    The 'black hose' goes from the bottom of the TB and works its way through the inlet manifold and then connects down behind the manifold. It sometimes comes off depending on what you've done previously.
    If it wont stay where it needs to be, superglue will help
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    sounds like the PCV hose which runs from the throttle body to the manifold , also check the purge hose under the throttle body running to the back of the manifold to the purge valve if this is loose it can make a whistling sound under accel and idle also check the vacum lines on the rear of the manifold.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Rocker cover gaskets are like $20 a Pair max from Holden and get some gasket goo to deal it properly... Fairly easy job
    VX S2 S Pack
    Dec 2009
    Ok, yeah the purge hose sounds like it might be the problem, it whistles bad under acceleration, im guessing it would be alot easier if i take the engine cover off to check the back of it.
  1. [General] [Buick]"How To" bypass hose and inlet manifold bung
    By LeaThaL in forum Holden Commodore How-To's
    Last Post: 08-04-2012, 10:24 PM
  2. vx inlet on vt?
    By VNSS90 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-10-2011, 09:44 AM
  3. Powersteering hose sitting on radiator hose
    By Hibbo_Jnr in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-08-2011, 01:13 AM
  4. Has any body replaced the stock fuel filter clips with new hose and hose clamps? HELP
    By sir_nick2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-01-2010, 08:51 PM
  5. How do I get the heater hose fitting out of the back of the inlet manifold?
    By AussieHomer in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2009, 01:00 PM
