Page 2 of 2 FirstFirst 12
Results 26 to 42 of 42
Like Tree6Likes
Thread: want more power in my vt v6
  1. #26
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by Not_An_Abba_Fan View Post
    The stock exhaust is better for bottom end torque, a larger system shifts the torque curve higher in the revs.
    OK, well I might replace with a Stock system when the time comes. These engines are already fairly poor when it comes to bottom end torque, without making it worse! Cheers.
  2. #27
    98 vt executive 9c1
    Jan 2012
    Harden Nsw
    Quote Originally Posted by Mick1988 View Post
    Why would you delete an LSD?????
    I would be doing roller rockers, diff gears and oxygen sensors. Even put some injector cleaner through the engine and open the plenum chamber up and clean all the carbon buildup (this is why you should use vPower).
    I'm wanting to do all these things on my VX shortly to give it a bit more kick and improve my fuel economy.
    i use injecter cleaner everytime i fill up. i was using w10 but told that was stuffing the motor/fuel system. so i went to standard fuel but might start using bp ultimate or shell vpower some sort of high octane fuel..how would i clean the plenum chamber? take the complete unit off the motor and do it that way and what do i use to clean it? cheers for all the advice huys.. i will be doing oxy sensors and look into doing diff gears but can diff gears fit a lsd?.. once again cheers guys..
  3. #28
    Jonah 101's Avatar
    Jonah 101 is offline I love photoshoppin
    vs executive Manual
    Jan 2012
    Tauranga
    I just used a rag and some carb cleaner to clean the plenum chamber.
    My ride-VS commo, Just finishing the manual conversion. Working out those annoying bits!
  4. #29
    98 vt executive 9c1
    Jan 2012
    Harden Nsw
    should i take the plenum off the manifold so nothing goes into the motor itself?
  5. #30
    2011 ve ssv ute
    Aug 2008
    burnie
    i put ss induction cold air intake extractors decent plugs and leads and run 98 octane fuel and it changed the vehicle completly
  6. #31
    98 vt executive 9c1
    Jan 2012
    Harden Nsw
    ive got an ss cai at a mates but i got to get to melb to pick it up. ive wanted to do extractors... what plugs and leads did you use?. ive only got bosh but its all less than 1000ks old...
  7. #32
    2011 ve ssv ute
    Aug 2008
    burnie
    i ran ngk irridum plugs and top gun leads i was also gunna put computer in mine and get it tuned up but i sold it and got a 6litre
  8. #33
    Jonah 101's Avatar
    vs executive Manual
    Jan 2012
    Tauranga
    Quote Originally Posted by jason_85 View Post
    Nah just take the top piece off and dont drop anything into the motor.
  9. #34
    98 vt executive 9c1
    Jan 2012
    Harden Nsw
    Quote Originally Posted by Jonah 101 View Post
    but wouldnt the carby cleaner and the sh1t that gets cleaned run into it?
  10. #35
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Quote Originally Posted by VYMAD View Post
    Compared to 4 cylinders and stuff the bottom end torque is actually fairly good.
    I don't know why you say it's poor. I have a 2.5inch exhaust and even 3.08 diff gears and my bottom end feels nice
  11. #36
    Jonah 101's Avatar
    vs executive Manual
    Jan 2012
    Tauranga
    yeh but its designed to be burnt up, when you use it on a carb you have the engine running. Plus it evapourates anyway buy the time everything is back together there is bugger all in the motor.
    If the engine wont start afterwards push the throttle to the floor and crank it.
  12. #37
    98 vt executive 9c1
    Jan 2012
    Harden Nsw
    ohh fair enough.. cheers for that mate.. ill pick some up tomorrow... ill rip the top off now to have a look, see how bad it is...
  13. #38
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    It's not the carby cleaner that you have to worry about, it's the thick black gunk that you'll scrape off that you don't want going down the holes. Stuff some rag down each hole, then before you remove the rag, vacuum the crap from around it first.
  14. #39
    Jonah 101's Avatar
    vs executive Manual
    Jan 2012
    Tauranga
    Oh right, yours will have gunk from the EGR. maybe you should pull it off.
  15. #40
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by Cameron P View Post
    It probably does feel good, but bolt a standard exhaust back to it and it will feel better.
    Visit my Facebook page
  16. #41
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Had the exhaust and extractors on it when I bought it so that might be why
    Although my mate in his Vz acclaim(175kw) can't get away from me say from a set of lights or something
    And daily driving I can get away with only using about 10% throttle If that... So the torque is there
  17. #42
    98 vt executive 9c1
    Jan 2012
    Harden Nsw
    i definatly will be cleaning the plenum.. it is discusting lol... im also looking into getting a shift kit and corvette servo for my trans as i think thats where im losing the up and go.. might need a service or something.. i dont really know.. but cheers guys...
  1. VZ centre console: Acc power to constant power.
    By Luke52 in forum Electrical Wiring / Questions
    Last Post: 08-10-2011, 06:18 PM
  2. [NSW] FS: New NOS VN-VS Power Mirror controls In Holden Packaging, Used VN-VS Power Mirrors
    By VKCOMMO in forum Parts And Other Items For Sale
    Last Post: 16-03-2011, 05:23 PM
  3. Power wire from central power windows??
    By zachy in forum Electrical Wiring / Questions
    Last Post: 07-12-2010, 12:30 AM
  4. Power versus non-power steering columns?
    By BaggedVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2009, 06:19 AM
  5. Desperatly Seeking Power + Power + More Power
    By kezza_4246 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2007, 10:28 PM
