Results 1 to 4 of 4
Thread: Check power train light? fault 19?
    VT Acclaim II
    Feb 2012
    melb
    Default Check power train light? fault 19?
    hey guys,
    just got a vt acclaim II auto v6 and so far the check power train light has come on twice, the first time i put my foot to the floor and the car was stuck in 3rd(i think) and was stuck at 2500 rpm! happend again today as i was going round a round about slowly and the light came on again! both times just by turning the car on and off the light would go away!
    so just before i checked the faults codes, came up with the usual 12 then with fault code 19 (Throttle position sensor (sticking open)), could this be causing the problem?
    thanks in advance!
    VT Acclaim II
    Feb 2012
    melb
    okay so did some more intense searching and found that they could be related, but if anyone has anymore info please feel free to share! im stil an amateur so please no hate
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Replace the TPS. Cheap and easy to replace. However, before you do that, make sure that the inside of your throttle body is clean and allows the butterfly valve to close properly. If it't dirty, buy a spray can of throttle body and carby cleaner (around $10) and follow the instructions to clean the throttle body. If that doesn't fix it replace the TPS.
  1. Check Power train light.
    By Ujellysv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-07-2011, 11:36 AM
  2. Check power train light only once....
    By sxc_sound in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-03-2009, 05:22 PM
  3. Check power train light - common problems???
    By exec57l in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-09-2007, 06:47 PM
  4. Check Power train Light!!
    By HIROLLA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2006, 07:35 PM
  5. Check Power Train ?
    By trademark in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2005, 10:49 AM
