Search for the how to thread guard removal would be covered there
I've already had a good long look and started to fall asleep trying to look for it![]()
Just start undoing bolts.. keep going till it comes off.
Its not really that complex.
If you find something is obstructing you from removing it.. remove that as well
And before you go make another thread about how to put it back on I'll tell you the big secret about how to do it..
Do everything you did to take it off, in reverse!
So sneaky I know but it works!!!
I just changed the same guard its easy mate just take the wheel off then take out the liner then reach in the back and undo the power antenna then its a couple of bolts down the back you get to with the passenger door open, two at the rear bottom behind the skirt, a few along the top under the hood, and a couple at the front below the headlight.
