Results 1 to 5 of 5
Thread: Vt ss oil leak
    vr berlina
    Aug 2008
    Default Vt ss oil leak
    I have an oil leak from my car which is quite slow, but ends up with a fair mark on the driveway after a night of being parked. The leak is at the front of the car, only a few inches back from the bumper and when I had a look under, there was oil on a rod not far from the bumper, no idea what it is. Anyone fill me in what it might be?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Is it red or black? My first answer would be the power steering return line on the pump could have a loose clamp, that will leak power steering fluid down onto the sway bar then onto the ground.
    Visit my Facebook page
    vr berlina
    Aug 2008
    holden vl sl wagon
    Dec 2011
    gold coast
    checked your oil filter done up tight and tappet cover gaskets are not damaged and in tight
    VT SS S2 Gen3 and VZ Exec.
    Jan 2011
    Power steering i'd say too, mine does the same, although is it an auto? there's a trans fluid line that runs across the bottom of the radiator that connects the two transmission coolers in which are in each radiator tank, could have a crack or a loose fitting there too.
  1. Air Con gas leak
    By bundy_boy in forum General
    Last Post: 12-02-2010, 09:48 PM
  2. gen 3 oil leak need help
    By camo24 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2010, 01:28 PM
  3. Bad Oil Leak, Need Help
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2009, 10:20 PM
  4. oil leak
    By gungazza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-08-2008, 05:25 PM
  5. Oil Leak
    By eagle13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-11-2007, 09:19 PM
