Results 1 to 4 of 4
Thread: stateman power hose replacement
    5.7ltr gen III v8 325hp
    Jul 2011
    saudi arabia
    Default stateman power hose replacement
    I have wh statesman and the short hose of the power steering reserviour leaks very slowly. I have to top it up every two weeks. I live in saudi arabia and they do not have any hose in stock. I tried a heater hose but it got bended where it curves. What kind of hose can I use. Heater hose will not work. I need something flexible.
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    Try tightening the hose clamps?
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    VY S V6 Ute Series II 2004
    Nov 2009
    The original Holden power steering hoses are specially shaped to suit and are reinforced inside with a coil.
    Sometimes you can be lucky and stop the leak by tightening the hose clamp (if your leak is at a join) but what usually happens is the hose clamp is tightened so much that the clamp distorts out of round and leaks as bad if not worse no matter how much you tighten it. The hoses have just enough length to reach so chopping a bit off and retightening isn't an option.
    I replaced both hoses recently here in OZ and it cost about $30 for one and $20 for the other shorter one (from Holden).
    Can you get your dealer to order the hose for you?
    VX Calais
    Jun 2008
    SA
    try transmission cooler hose. Should be able to bend it close to the original shape so that it'll fit
  1. Low Pressure Power Steering Hose
    By NewVPOwner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2010, 05:24 PM
  2. Changing power steering hose
    By scbh81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2010, 02:05 PM
  3. hose of transmission or power steering
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2007, 11:52 PM
  4. Pressure Hose on Power Steering...
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2006, 11:02 AM
  5. Power Steering Hose
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2006, 03:02 AM
