Results 1 to 10 of 10
Thread: Water getting into the back floor of VT
    VT COMMODORE
    Dec 2008
    Default Water getting into the back floor of VT
    Ive got a VT. When it rains, water gets onto the rear drivers side floor. With the recent rain, it has gotten quite bad. Its a patch near the shaft cover. I cant feel water near the edge and I dont see how it could get past the seals.
    Has anyone experienced this?
    VT
    May 2010
    Wollongong
    Lol exact same things happening to my vt and can not find a leak anywhere for the life of me it's like it's coming throught the floor.
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Look under your car there are rubber bungs in the floor. Quite common for them to come dislodged
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    VE SS Sportwagon
    Feb 2010
    Brisbane - Southside
    take the door trim off and ensure the plastic sealing up the door cavity is sealed all the way around.
    I just fixed this in my VT.
    While you are there ensure that the door drains are clear.
    VXII Berlina 3.8L
    Oct 2005
    I have the same problem, only it was a small pool of water sitting on the internal door rubber of the rear passenger door on the driver's side. I removed the door trim and found that the water was seeping through the seal at the bottom of the plastic water deflector after I sprayed the door with the garden hose. The water was gushing through the door strip. This has probably been happenning for years and the water just ate throught the mastick that's used to attached the water deflector to the door. I have had no luck in finding the mastick to repair the leak. Another poster on the forum has recommended using race tape to fix the seal.
    Mummbles, what did you use to fix to repair the leak?
    VT COMMODORE
    Dec 2008
    VT COMMODORE
    Dec 2008
    Hi Mick
    Can you post photos of the rubber bangs you are talking about? What are their purpose?
    VXII Berlina 3.8L
    Oct 2005
    Sorry VTCommoDude, I fixed the problem without taking any photos. FWIW, I bought new weather strips for both rear doors and the mastick from the local Holden dealer and resealed the deflector. I replaced the weather strips on the doors because I found that they had shrunk slightly over time and weren't limited the amount of water getting inside the door.
    If your not sure where the water is coming in from then your going to have look at all possible options and rule them out one by one until you find the cause. Sorry can't help any further. Happy to answer any more questions.
    VT COMMODORE
    Dec 2008
    I think I found it! On the inside bottom of the doors, there are little rubber grommets with small holes to drain the water. I noticed that they point over the door seal. So if a lot of water gets in the doors, it goes straight over the door seal and onto the floor. I cleared them out and drilled small holes in the very bottom of the door, to let the water drain onto the door sill before the seal. Last couple of heavy rainy days... no water in the car. Obviously another design fault by Holden, but a simple fix.
    GTJevon is offline Green Bandit
    VT V6 Manual S Pack
    Mar 2012
    NSW
    Replaced door seals from Holden, fixed the problem for me.
  1. pls help:Water leak passenger side floor
    By scottyz999 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2012, 04:34 PM
  2. Water on Drivers Side Floor.
    By Onecontrolfreak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2007, 01:23 PM
  3. Puddle on back floor
    By darktele in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-12-2005, 06:28 PM
  4. water on the floor
    By VRFURY in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-08-2005, 10:19 AM
  5. Water coming out of floor vents
    By Phiness1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2004, 08:57 PM
