Results 1 to 8 of 8
Thread: snapped a stud!! (radius rod plate)
    vt wagon
    Jan 2012
    randwick nsw
    Default snapped a stud!! (radius rod plate)
    i recently snappe one of the four studs that hold the radius rod bushing plate.
    does anyone know if this is going to be an issue, if so, any posssible solutions??
    its the top left one on driver's side
    VT Executive
    Oct 2011
    Haha, I've done that at work once before. Ended up knocking it out with a punch and using a nut and bolt IIRC.
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    You could get a set of "easy outs" which is a screw type bit with opposite thread. Its for removing bolts that have the head f*cked out. Bunnings or and hardware shop have them.
    or
    Drill a smaller hole down the center and re-tap a new thread into it and weld a smaller bolt into it, then undo it that way. spray it with a lube of some sort to help remove it.
    http://www.tools-plus.com/irwin-53535.html
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    vt wagon
    Jan 2012
    randwick nsw
    so what your saying is the bolt is not welded into the back of the frame and i can undo it or punch it out?
    is it going to be an issue or can i leave it, seems like big centre nut takes most of the load.
    thanks for tha advice!
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    hmmm come to think of it, they might be welded to the frame sorry cant remember now
    VT Executive
    Oct 2011
    They're only spot welded, if you can't knock it out easily take a drill to it.
    You might have to use a 90 degree air drill though, don't think there's a whole lot of room to play with in there...
    vt wagon
    Jan 2012
    randwick nsw
    VT Executive
    Oct 2011
    If it were my car I wouldn't leave it but i suppose if you have to drive on it you could get away with it for a little bit. Probably better off waiting for someone with a bit more know how to answer that one.
  1. Replies: 0
    Last Post: 28-12-2010, 05:20 PM
  2. Snapped a wheel stud!
    By sprocket in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-04-2010, 09:21 PM
  3. Snapped Strut Stud!!! HELP!!!
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2009, 10:45 PM
  4. Snapped pressure plate bolts question.
    By VSSS_5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2008, 10:37 PM
  5. 10 stud vs 5 stud Rotors on Back of IRS VS Acclaim
    By pugga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2007, 09:43 PM
