hey iv got a problem with my back wheels it is lowered and the bottoms of the wheels are sticking out iv had a camber kit but it still is very bad has anyone else had this problem?????
The most common thing in commodores
Current Ride:2003 Vy SS series2. Single mount T04Z and intercooled. 224 232 @590" Vcm Suite Cam, Crow Cam Valve Springs, Aftermarket Lifters, Ls1 Double row rollmaster timing chain. 3000rpm stall converter, 3:46 Diff Gears. Still being tuned!
Previous Rides:97 VS Acclaim Stocker /02 VX S Pack 5sp, Raptor Charged Intercooled 307rwhp
but is there any way of getting them any straighter???????
and also how long do yous get from your back tires before you need new back tires???
it that the only thing???
i put a VZ rear end in mine at the start of the year and its the best thing i have ever done ... wheels sit nice and straight and when i look under there now there isnt a strip of wire showing every 2 months.. i got the sub frame for $550 and did it myself its not hard. i would of already saved that amount on tyres hahah ever since i installed my cam i dont seem to get much rear tyre life but now i dont have to worrie about the inside being bald when the outside is untouched![]()
If in doubt......FLOOR IT!!!
I have a series 2 Vx which is the first to have the camber kit standard and my tyres last roughly a year... And in that year that produce a fair amount of smoke as well
I know its a year because every rego I need tyres![]()
You should try running hard compound tyres
yeah choice of primes or options is critical
The lower you go, the worse the camber will be, simple as that. My car is at stock height, and no camber kit or anything, just raw VT. Never had an issue with camber wear, I rotate my tyres every 10,000km and to be honest my fronts usually wear quicker.
The New Ride - The Class 2 Shuttle Craft (VE)
I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
When I light the nitro on my HQ 454 Monroe!
Lol my fronts last ages =P
Adam im assuming yours is series 1.. If you wanna see the camber I have and if you have fb inbox me your full name and I will add you and show you a picture.
I can't put a pic up on here cause I'm on my phone
I have ssl springs all round btw
