Results 1 to 13 of 13
Thread: VT Gen 3 intermittent low idle
    VT SS S2
    Jan 2011
    Cool VT Gen 3 intermittent low idle
    Sometimes when I pull up to a stop my engine sounds like its about to stall, it almost sounds like when you slow a manual right down with the brakes without pushing the clutch in (but its an auto), if i slip it into neutral the idle pops up to normal. It never actually stalls, and it only does it sometimes. Anyone come across anything like this before?
    VY SS
    May 2011
    Auckland
    Could be a small vacume leak?
    If you think it's tranny related, I would just change the fluid. Nice and easy and it will be smoother for it
    VT SS S2
    Jan 2011
    Yeah I'm thinking tranny, due to the fact I can actually hear the load come off the engine when I put the trans into neutral, I guess I was wondering if its a known symptom of something (serious or not) that im unfamiliar with, I'll service the trans hopefully that'll help.
    Cheers.
    Series 2 VX SS
    Dec 2011
    What's the best way to change the fluid without letting too much air sneak in?
    Munz's Avatar
    Munz is online now Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    don't worry about air getting in, I'd be more worried about spilling the fluid over the engine
    Series 2 VX SS
    Dec 2011
    Because i topped up my fluid and got the same intermittent idle as discussed above. I'm guessing it was because too much air got in?
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Try a PCM reset
    Quote Originally Posted by Munz View Post
    PCM reset Proceduce
    Motor at operationing temperature a MUST
    1.Turn ignition ON
    2. Model VT Remove PCM/BCM fuse number 4 which is F31 Note: for VX,VU ,V2 remove fuse F29 10amp Eng Cont/BCM
    3.Wait 20 seconds for the Car to chime to you.
    4. Turn ignition OFF.
    5.Model VT Replace PCM/BCM fuse 4 which is F31 Note: for VX,VU ,V2 remove fuse F29 10amp Eng Cont/BCM
    6. Proceed to the idle learn Procedure.
    CLEARING THE DTCS
    To clear a current diagnostic trouble code from the memory of the PCM, the PCM power feed must be disconnected
    for at least ten (20) seconds, or the Tech 2 scan tool must be used. The battery power feed can be disconnected
    by:
    • Disconnecting the negative battery terminal
    • Removing the Fuse F31 in the engine compartment fuse/relay panel.
    CLEARING THE DTC HISTORY CODE
    The Tech 2 scan tool is the only tool capable of clearing the DTC history code. Disconnecting the battery will not
    erase DTC history. The Tech 2 scan tool sends a special message to the PCM to erase the DTCs.
    IGNITION CYCLE DEFAULT
    If the ignition is cycled (OFF and ON) 50 times without a particular fault resetting, that DTC will be cleared from the
    PCM memory and the ignition cycle counter in the PCM will reset to zero. This is another way to clear any code, but not all, but might help you out.
    Then follow the idle learn procedures
    Idle Learn Procedure
    Anytime the powertrain control module (PCM) or the battery is disconnected, the PCM loses power
    by removing F31, or the PCM is reprogrammed, the PCMs learned idle position is lost.
    Perform the following procedure in order to return the learned idle to the correct position:-
    Automatic Transmission
    1. Turn OFF the ignition.
    2.Restore the PCM battery feed if removed, or replace fuse 4 which is F31.
    3.Turn OFF the A/C controls.
    4. Set the parking brake and block the drive wheels.
    5.Start the engine.
    6.Ensure that the engine coolant temperature is more than 80 Degrees.( Check in Mode Up button).
    7.Shift the transmission into Drive.
    8.Allow the engine to idle for 5 minutes.
    9.Shift the transmission into Park.
    10.Allow the engine to idle for 5 minutes.
    11.Turn OFF the engine for 30 seconds.
    Manual Transmission
    1.Turn OFF the ignition
    2.Restore the PCM battery feed if removed, or replace Fuse 4 which is F31.
    4.Set the parking brake and block the drive wheels.
    5.Place the transmission in Neutral.
    6.Start the engine.
    7.Ensure that the engine coolant temperature is more than 80 Degrees.( Check in Mode Up button).
    9.Turn OFF the engine for 30 seconds.
    Series 2 VX SS
    Dec 2011
    Tried the PCM reset and if anything it made things worse, nearly completely stalled at one point during the 5 minute idling period!
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Faulty TPS or coolant temp sensor.
    Visit my Facebook page
    Quote Originally Posted by 191kieran191 View Post
    contact Not an abba fan he is the best
    Nuff said really.
    1999 VTII SENATOR
    YOU BUY!!!
    ALL SERIOUS OFFERS CONSIDERED
    http://www.carsales.com.au/private/d...o=Stock&items=[Make:HSV,Model:SENATOR,Series:VT%20II]&sort=default
    Series 2 VX SS
    Dec 2011
    Yep tried the idle learn procedure as well straight afterwards like the guide says.
    I'm going to reset the sensors first to see if that changes anything.
    This idle problem literally happened the second after i added some more transmission fluid to the car. I don't know how but it seems that the tranny fluid was the cause?
    Idles the same when the clutch is in and when it is out.
    Ideas??
    2002 VX SS
    May 2011
    Quote Originally Posted by Anglosaxon View Post
    I had the same thing happen a few weeks ago - as i pulled up to a stop the revs would drop to about 200-300 and almost stall so i got my tuner to adjust the fuel trims and it
    fixed it straight away.....
    DONT GET MAD...GET EVEN
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    How clean is your throttle body/IAC?
    I'm more leaning towards a vacuum hose, pretty sure behind the manifold it splits into 2 hoses, check there
  1. Intermittent High Idle
    By MikeCuzzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2011, 09:13 PM
  2. 01 wh v6 intermittent no idle
    By jem001 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2009, 07:17 AM
  3. intermittent miss at idle help
    By danny1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2008, 08:47 PM
  4. Intermittent idle problem
    By Fr3ak+-- in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 12:34 PM
  5. Intermittent Rough Idle
    By jonesz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-03-2007, 06:52 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
