Results 1 to 11 of 11
Thread: VT V6 constantly missing under acceleration
    VT Acclaim wagon. Subaru Liberty 4WD wagon
    May 2004
    Hiawatha (Gippsland)
    Exclamation VT V6 constantly missing under acceleration
    As the subject says, the engine is missing constantly under moderate to heavy acceleration, sometimes even under light acceleration, and the problem is slowly becoming worse. My first guess is I have a rooted spark plug lead?? Or could it be more complex then this...MAF sensor?
    Any idea's?
    VZCalZone's Avatar
    VZCalZone is offline now choppin the VZ
    vz calais, vx2 exec
    Sep 2005
    New plugs and leads are always worth a try. Even if it's not the problem it sounds like you havn't replaced them for a while/ever. Even make sure existing leads are connected correctly and firmly.
    VE SSV
    Sep 2005
    Perth, WA
    after changing leads and plugs its worth checking the PURGE HOSE and a throttle body clean would be good too.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    could be one of your coil packs on the way out
    I'm only speeding cos i need a poo
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by BrentVR
    Any idea's?
    Could be leads,plugs or one of the coil packs.Look VERY closely for a hair line crack.
    rick'o Guest
    VT 1997 Holden Commodore
    Feb 2008
    Wink Car spluttering cleared by itself after 2 months use
    I had the worst problem with my vt 1997 holden spluttering and jerking along the road for over 2 months. it started gradually, got worse and then it just cleared by itself - thank god. i too thought it was spark plugs, leads and petrol pump.
    KRUPTD is offline VN BT1 5L
    VY SS Crewman,XE Falcon,HJ V8 panel van,HZ tonner
    May 2007
    Griffith, N.S.W
    VT's and VX commodores had problems with there fuel pumps,breaking down causing power loss/starting issues and missfires underload problems.Was due to the fuelpump harness and connector.They also had problems with the fuel send unit too.Saying that there would be more or less fuel that was actually in the tank.But a common thing to happen on VT's is the dirty air flow will cause a miss under accleration.Give that a clean and see how you go.
    Also another thing id like to mention we fitted a new fuel pump and fuel sender assembly to a VZ with the alloytec motor.These fuel pump setups and very different to your VT VX VY setups,because they have the fuel reg in the fuel sender pump unit in the tank.And its near impossible to check fuel pressure on a VZ,but i spose there would have to be a way,will find out.
    tjp445's Avatar
    tjp445 is offline SonicBoom
    VT, Auto all stock for now muuhaha..
    Sep 2005
    wantirna
    mine has started doing the same thing now what can i do i just had the car full serviced 4weeks ago got new plugs n leads but can funny thing is my RPM is sitting at 2,000 now on idle whats going on here?
    TJP-445 Big Yellow
    Dec 2009
    Quote Originally Posted by VZCalZone View Post
    Before you go and buy new leads why not remove them and check them with a multimeter? They may not be the problem. There resistance must be within a certain range which you can find in a workshop manual.
    As well as the leads check for a cracked spark plug.
    VZ Calais Impounded?
    May 2010
    check lead # 4 .. i have had these leads on 2 different cars rest on the manifold and burn through. Factory leads have a 90 degree coupling i think, aftermarket ones are an extension of the lead and straight through plug
  1. Vn V6 Constantly Stalls
    By mars in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-11-2008, 02:02 PM
  2. Boot light constantly on
    By FadeToBlack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2007, 11:27 PM
  3. Flasher unit constantly ticking.
    By hshaw in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-05-2006, 08:00 AM
  4. seat constantly reclined
    By toddgalloway in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2006, 12:06 PM
  5. Lights constantly on
    By veclubby in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2005, 11:00 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
