Hello, No brake lights on my VX, I have checked the fuse and globes-all ok so Im going to replace the brake light swich. Could some one tell me the best way to go about this, as there appear to be some obsticals in the way. Thanks Ronno
Is the fuse the correct amperage? when the lights are turned on, is power getting to the fuse, the switch, relay and the globes?
Start following the circuit and find out where the fault is. If anything you may have a short somewhere or the switch is faulty.
Let us know how you go.
