gysenn
- Jan 27, 2010
- 12
- 0
- 0
- 2000 VT Executive S2
Hi guys. I've got a Series II VT executive, and just bought a new set of tail lights.
The lights are the common black altezza 'monaro' lights.
First of all, I've seen a lot of people saying that the left reverse light doesn't work when you do this change over, and you have to run an extra cable to fix it. Is this true? Is this in all cases, or is it just a problem some people are having? Any tips on what to do / how to do it?
Secondly, about ten minutes ago I finally figured out how to pop out the stock lights. I put the new lights in place, only to find that the connection cable won't fit through the hole. What's the best way to make the hole bigger?
As I'm sure you can tell, I have absolutely zero modification or electrics knowledge, so go easy on me haha.
Oh, and no responses about changing the boot garnish thanks. I think it looks great alongside the black lights, and I plan to leave it there.
