bongoozy
Went to Pedders for 28 point check and was advised that the Self Levelling is not working and new rear shocks are required.
Decided to replace the rear shocks from self levelling to standard KYB P/N: 344312 shocks for $110 set.
I have already checked the forum and found different views (as under) of how to change the Self Levelling to Standard shocks:
There is a little bar (metal rod) under the car on the right side of the car near the rear axle. more towards the diff centre i think. its about 2.5 inches long and has ball joints at either end. just disconnect one end from the ball joint connection and your auto levelling is disabled, basically. its that joint that detects the change in height thus telling your auto levelling to adjust height.
Change the shocks and take the fuse out of the level ride under the steering wheel.
Remove the self levelling compressor and switch.
Make sure you unplug the self levelling pump at the plug above the diff or you could have problems with the ABS, DO NOT pull the fuse for the SL suspension or you will burn out the abs pump.
CAN ANYONE PLEASE HELP WITH A PROCESS OF HOW TO REMOVE THE SELF LEVELLING REAR SUSPENSION SYSTEM FROM A HOLDEN STATESMAN WH TO REPLACE IT WITH STANDARD SHOCKS.
Last but not the least I believe there won't be any issues with pink slip in NSW with this conversion since there are members who have already done it.
