See the rad hose on the right of the pic goes onto a dome ali piece , thats the thermo housing , has the bleed screw on top , the thermostat is inside that.
To get to it you will need to remove the throttle body and U bend off the back of the blower then it has 2 bolts holding it down , order a new housing , U hose and gaskets before you start removing it is my advice.
