Results 1 to 6 of 6
Thread: unused EGR port on pacemakers
    VT Calais L67 (conversion)
    May 2012
    WA
    Default unused EGR port on pacemakers
    hi all,
    just got pacemakers installed today... as my L67 engine does not use EGR, and the port is unused on the pacemakers and is just open to air now.
    Im guessing it is releasing toxic and hot gases into the engine bay every time I drive it now
    is there any good way of blocking it off? I might still have the EGR pipe from my old ecotec lying around....
    Or maybe I shouldnt worry about it?
    What do you guys think?
    VX Berlina LS1
    Feb 2009
    Shepparton
    I'm not sure why that EGR port would've been opened by default on Pacemaker extractors, because there's a thread here EGR Valve install help, where one of the replies links back to a Pacemaker installation page, that says that all Pacemaker EGR's are closed by default, and have too be pre-drilled if needed
    VY s m5 supercharged
    Aug 2008
    You can get a bung from bunnings that will fit it. Check in the plumbing section you will find it there. Thats where i got mine when i did the l67 conversion.
    If you got them fitted why didnt the shop block it off for you. Also normally the l67 headers are bigger did you have them already??
    May 2012
    WA
    cheers guys,
    yes I did see that thread, but in the Pacemaker fitting instructions its sayd "only for PH 5059" that you need to pre drill the EGR... so Im assuming the PH 5060 (the ones i have) will have the hole drilled open already.
    0081, what do you mean? I had stock L67 headers before... now Ive upgraded to Pacemaker PH 5060 headers, they are 1 5/8 primary and 2 1/4 secondary size.
    I'll check for the bung at Bunnings. No idea why they didnt block it off.... must have forgotten. I'll have another close look tomorrow when there's better light.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Do you know for a fact its open? Just put something light (but not flammable) over it and see if air is blowing out of it.
    I'm sure you would notice if it was open as it would be horribly loud and letting out air at extreme temperatures.
    "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
    Now with my very own Tech2....YAY.
    Aug 2008
    I have seen some pacemakers that dont have the egr pipe coming out of the headers.
    If you want a pic of my exhaust let me know.
    But is it even open, you should be able to feel something coming out while the car is running and it will be noisy
  1. Replies: 2
    Last Post: 29-06-2011, 02:07 PM
  2. How long can fuel go unused in a car?
    By turmoil117 in forum General
    Last Post: 27-05-2011, 08:38 AM
  3. 9 port 12 port intake manifolds?
    By bruiserbrad in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-02-2011, 01:44 AM
  4. [VIC] VZ Alloytec 190 unused
    By Dr Goggles in forum Parts And Other Items For Sale
    Last Post: 20-12-2010, 10:07 AM
  5. [VIC] SWAP: Turbosmart V-Port BOV, for Turbosmart Plumb back or dual port
    By Wagon_Wheel in forum Swap / Wanted to Buy / Trade
    Last Post: 14-07-2009, 05:24 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
