vxs
hi guys.. here is the easiest way to connect your existing steering wheel controls.for VTVX with existing controls.. to your after market stereo..all you have to do is locate 2 wires on your factory radio plug. the 2 wires you need are (brown with white dots) witch is your signal wire.and the other is (black with a white stripe) whitch is your ground wire.. all you have to do is connect your (key1) wire from your new srereo to the brown wire and connect your radio black ground wire from your new stereo to the black wire with whith white stripe.. i have some pics here for you with all connections .. i hope it helps
