Results 1 to 12 of 12
Thread: Power window wont fully close vx calais
    VXII Calais S/Charged 6
    Sep 2012
    Matraville
    Default Power window wont fully close vx calais
    Hi guys,
    Just noticed today that my passenger side window wont fully close on my VX Calais. It opens fully and stops at the right point but it wont raise to the top of the trim. Kind of annoying because water can now get in and it looks like it is going to rain tonight :S
    I cant lift the window any higher or move it in any way unless I use the button in the centre console. Is there some way to reset the window motor or something? I'm a little desperate.
    Thanks so much for your replies.
    Wh statesman
    Jan 2013
    Hi mate,
    I'm pretty sure it would be an issue with the regulator rather than electrics. Although you could pick up a cheap switch console and try it out just to be sure. Also make sure there are no loose rubbers or window guide channels to foul the movement
    Sep 2012
    Matraville
    Ok just took the door trim off, can't see anything that would be obstructing it. The slides are clear, there is no rubber getting in the way, the scissor mechanism is free to move it just seems to stop as though it's hit the top before it actually does.
    Wh statesman
    Jan 2013
    Quote Originally Posted by tsommerville View Post
    I'm not sure then sorry mate, it may be a faulty switch mechanism, although if that was the case it probably wouldn't work at all. Hope you work it out mate
    VX Calais LS1, SY Territory Ghia
    Mar 2010
    There's an adjustable stop at the top of the frame. That hasn't dropped down has it?
    Sep 2012
    Matraville
    No :'( I just looked at it. Now I've got an extra problem of every time I lower my window it opens the door :/ And whilst it is nice that I now have an electric door opener, I'd prefer something a little more engineered.
    vt 98 hsv clubsport
    Feb 2013
    glenroy
    i had a problem with my rh/r window and it would go down but would not go up .and it was the main window switch i went to preston motors and he pluged in a new window switch and no go then he plug a new main window switch and it worked so i just bought the main window switch .ow and a new window reg is 180 new .from preston motors.
    Mar 2010
    If the the door is opening with the window movement there's got to be something mechanical come to grief in there. All you can do is pull the trim off and do your best to see what's going on.
    hj kingswood
    Sep 2011
    Melton
    When it stops, does it make a banging/thumping sound when it stops?
    I have this problem at the moment, but on a vs, couldn't find anything for the hour I was in the door, until the window was in the right place, I look down, and 3 teeth are worn on the regulator.
    Sent from your god, for you to worship and give money
    Sep 2012
    Matraville
    No unfortunately, the only noise it makes is when (and I'm guessing here) it catches on the door lock mechanism and releases it. For the rest of it's travel it sounds completely normal, just like any other window. I'm just gonna say stuff it and give it to a workshop to fix, this is starting to become too much of a pain to keep buggering around with. Thanks for all your suggestions anyways guys!
    hj kingswood
    Sep 2011
    Melton
    One just gets an inch from the top and just goes bang bang bang until I stop, so then I have to get out and shove it up the rest of the way, I'm yet to fix it, I'll have to buy a new regulator next week
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    See if the attached instructions are any use in fixing your problem:
    Attached Thumbnails Attached Thumbnails Power window wont fully close vx calais-vt-front-window-adjustment.jpg
  1. power window wont close all the way! crunching/slipping gears!!!
    By georgeyboy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-05-2012, 04:02 PM
  2. vt power window wont go down
    By rubaduckee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2010, 06:41 PM
  3. vn calais power window wont open or shut
    By grovers_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2010, 07:53 PM
  4. VT Power window wont go up!!
    By mbvp73 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-02-2010, 08:21 AM
  5. What wires to bridge to close power window?
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-08-2009, 01:33 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
