+ Reply to Thread
Results 1 to 7 of 7
Thread: Traction Control
    Apr 2004
    How does the traction control work (of the diff or brakes) and how do i tell if its got a LSD diff?Its a 1998 vt Berlina.
    jules's Avatar
    jules is offline we like the bun jules Statesman
    pimpin
    Dec 2003
    i'm pretty sure it works off the ABS system. some cars retard the ignition timing (eg. old F1 cars)
    WeeMan Guest
    yes it does work off the same sensors as the abs. when it there is low traction in the manual it says that it reduce the torque
    jafo's Avatar
    jafo is offline lurker since 2003 jafo Executive
    1999 wh statesman
    Yetisports 3 - Seal Bounce Champion!
    Oct 2003
    adelaide
    if you look at the diff on the rear plate there is normally a tag that tells you if it is lsd
    three thing in life are guaranteed
    taxes
    death
    and car repairs
    Oct 2003
    QUOTE (skb @ Apr 5 2004, 11:30 PM) How does the traction control work (of the diff or brakes) and how do i tell if its got a LSD diff?Its a 1998 vt Berlina.
    a tag on th side of th diff the 2nd code is if ABs is fitted.
    EF EC CONVENTIONAL - V6
    ED EE LSD - V6
    EA EJ CONVENTIONAL - V8
    V6 Supercharged and
    Wagon with
    manual transmission
    EB EH LSD - V8,
    V6 Supercharged and
    Wagon with
    manual transmission
    Oct 2003
    also if you jack both wheels off the ground and turn one side both should turn the same way if lsd. of not they turn the opposite ways to each other.
    or do a burnout lol
    Apr 2004
    Thanks for the replies..... question answered.
+ Reply to Thread
  1. Traction Control??
    By beetle81 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2010, 02:26 PM
  2. Traction Control...
    By KBone in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-01-2007, 03:34 PM
  3. traction control
    By matt_brown in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-03-2006, 09:14 PM
  4. VY Traction control?
    By atreidae@optusnet.com.au in forum Electrical Wiring / Questions
    Last Post: 30-01-2006, 11:50 PM
  5. Lpg And Traction Control
    By skb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2004, 10:10 PM
