Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Brett_jjj
Thread: Proper height of the oil pressure relief valve spring
    VY Berlina / VZ SS LS1
    Sep 2012
    UAE
    Default Proper height of the oil pressure relief valve spring
    Been searching for hours now trying to know what the right height/length of the oil pressure relief valve spring for the VY is. I got two of them off similar oil pump relief valves and one is considerably shorter than the other. Don't know which one to go with. Anyone?
    vs commodore
    Oct 2009
    Tamworth NSW
    I couldnt find the specs for the oil pressure regulator valve spring free length for VT to VY ecotecs, but I can tell you that the VS ecotec oil pressure regulator valve spring free length should equal 66.3mm. Id say the VY ecotec would be the same.
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Sep 2012
    UAE
    vs commodore
    Oct 2009
    Tamworth NSW
    If your spring is shorter than 66.3mm, then its probably lost some of its strength and/or has probably collapsed, and a weaker oil pressure regulator spring will drop the engine oil pressure.. Id replace it with a new one.
    Sep 2012
    UAE
    Quote Originally Posted by Brett_jjj View Post
    Yeah, i will do that. Its gonna be hard finding one though ....
    Thanks all!
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Order one from Australia. They are a few dollars and most dealers will have one.
    "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
  1. [VN-VP] [Buick] How to check oil pressure relief valve spring length
    By azzfox in forum Holden Commodore How-To's
    Last Post: 27-09-2016, 02:00 PM
  2. king spring height
    By kngsv6 in forum GSL RallySport
    Last Post: 29-10-2010, 01:02 PM
  3. Spring height measurements
    By Stan003 in forum General Discussion
    Last Post: 16-03-2010, 07:37 PM
  4. FE2 Spring height
    By broderikb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2006, 02:22 PM
  5. vb - vk spring height??
    By veeque92 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-12-2005, 12:28 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
