+ Reply to Thread
Results 1 to 16 of 16
Thread: Lowering a VX Commodore
    2008 VE SV6 Atomic Green w/ 20" Supersports
    Sep 2005
    Canberra ACT
    Default Lowering a VX Commodore
    Hi guys, I am looking at lowering my VX1 Commodore Equipe. I have upgraded the standard 15" wheels to 18" BSA-291's. I have thought about lowering it about 2.5" front and 3" to 3.5" at the rear on pedders sports ryder suspension. I have also considered Pedders extremeX adjustable suspension. What are your opinions on how far i should lower it and what suspension i should use?
    VK Wagon Guest
    I think you should lower the car 3" alround with kings springs. It worked my old vy ss with 19" rims
    VX Commodore Equip S2
    Sep 2005
    I got my VX lowered with 18" rims on it. I got superlow king springs put on. They lowered it about 2.5" at the front and 3" at the back and it sits and rides really well. Well worth consideing. I got my wheels and springs done at the same time which saved a bit of cash too.
    Hairy Eater's Avatar
    Hairy Eater is offline Banned Hairy Eater Executive
    2000 VX Executive V6
    Nov 2005
    Queensland
    Sep 2005
    Canberra ACT
    I have heard a bit about rear tyre wear, that's why i have considered adjustable suspension.
    02VX & 07VE SS
    Sep 2005
    Make sure that if you change your stocks wheels/mags to different profile/sized ones that you get the ppk values updated at holden so that your speedo will still read correctly
    Sep 2005
    Also, you may need to get a rear camber kit fitted to ensure that the rear tyres wear more evenly. You can get the camber measured to see if you require a camber kit. Mine was measured and didn't require any adjustment. It is a 2002 VX Equip and has 18"s on it with super low king springs.
    Sep 2005
    Canberra ACT
    yeah i'll get it measured. My VX Equipe is a S1. I hear there is a problem with it.
    VXBullett Guest
    It might be a good idea to see how much you can legally lower your VX before you do it, just in case you are forced to make costly adjustments later.
    VE SSV
    Sep 2005
    Perth, WA
    a - i wouldnt use pedders. better to use Lovells or Kings. Pedders is a rip off and shit
    b - camber kit is a must
    c - if u put the proper low profile tyres on your 18s you will not have to adjust speedo as Marcu5 suggests.
    d - NOT ALL vx models have a camber/tyre wearing problem. not matter what people say. Garth has clearing stating this on the two SHAME...HOLDEN SHAME threads where people are getting carried away
    e - dont lower it 2.5" at the front and 3.5" at the back because your asking for camber trouble and unless you never expect to drive over a speed bump or on nothing but a flat road then go for it.
    i understand people lowering there car to handle better and look better but some people are taking it too far then complaining. PLUS there are laws to the limits and insurance companies will reject insurance and claims if too low by there policy wording
    you will scrap everywhere and have the cops hassling you.
    be smart and reasonable about the choice not careless :b:
    Sep 2005
    Canberra ACT
    I will probably go 2.5" front and 3" rear. I have thought this as i measured the ride height and the rear is 1" higher than the front so i would like to even it out a bit
    vx executive s
    Nov 2009
    brisbane
    Default lowering xv
    hey - i have got my hands on some awesome looking xhp shoreline chromes- 19" .... am goin to put them on my commo vx s..... also goin to put on some kings super lows and gas shocks ( munroe).... 1) will i need camber kit for the rear...???????
    what the best way to drop the front to match the wheels as the standard level looks terrible............ anyone advice would be great
    damo vx
    vt berlina
    Dec 2009
    i have a vt berlina with 18s 235 45 have ordered superlows will it ya reckon it will scrape?
    VT
    May 2009
  15. #15
    VT acclaim
    Dec 2009
    Default Lowering camber kit for a VT
    Hi guys, I'm new here..... so G'day.
    I've got a VT that has been lowered, and I understand that there is a camber kit available to fix the tyre wear problem on the rear end. Were can I get one from and how hard are they to fit? Where is the best place to buy one from? Any help would be most appreciated.
    Oh I'm in the Geelong area too.
  16. #16
    VT
    May 2009
    Nolathanes 46138A Kit is what you need you can order at your closest auto parts or supercheap auto info on it on the site below
    http://www.nolathane.com.au/bulletin...-%2046138A.pdf
+ Reply to Thread
  1. Commodore Lowering Kits!
    By gslrallysport in forum GSL RallySport
    Last Post: 05-11-2011, 09:28 PM
  2. lowering vt commodore
    By Whitevtberlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-12-2010, 06:41 AM
  3. Lowering Of VZ Commodore
    By littras in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-01-2010, 04:43 PM
  4. Lowering A Vl Commodore
    By Cherrys in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-02-2009, 09:32 PM
  5. Lowering a VS Commodore
    By pano in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 06:18 PM
