Can someone please explain to me how to install new headlights into my VX?
I think I have to take the front spoiler off as well to do it?
Can someone walk me through it, or send me a link that tells you how?
THanks,.
Remove front bar.. Undo three bolts on the headlights.. Simple..
Front bar has two screws next to the mudguard on each side, one of them is on the underside of the car.. Three when you open the bonnet in front of the grille are three metal screws. They have thick washers on them. Take them off also with a screw driver
Then just pull the front bar off from the side first..
Then simply disconnect the wiring harness and reconnect.
Reverse the procedure to install..
Do not attempt this while the car is in motion !![]()
