+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 38
Thread: Cheap cheap effective mods for ecotec???
    jpvx Guest
    Default Cheap cheap effective mods for ecotec???
    G'day all,
    Just wanting some advice on good cheap mods for a stock v6 ecotec. I only want to spend about $2500.
    What sort of power increase should i expect and where can I get it done in Melb??
    burnz's Avatar
    burnz is offline dah dut dut da dah burnz Caprice
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by jpvx
    G'day all,
    a set of headers and a chip pakage you may have to allocate more money
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    jpvx Guest
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    What sort of increase in power should i expect??
    nothing to serious however it is the best bang for your $$$$ (10/15 kw's)
    Powered By Garrett
    VE SSV
    Sep 2005
    Perth, WA
    Exhaust, extractors, diff ratio change and a chip.
    it will put a BIG grin on your face
    HDT_aero is offline resident bush mechanic HDT_aero Executive
    manual VN aero
    May 2005
    SA
    ^^^^ all true except they wont be cheap those four things will set you back at least $1500 second hand
    im not admiring your car im looking in disgust
    jpvx Guest
    manual VN aero
    May 2005
    SA
    gear change is around $1000 - $1200 new including labour (ring around diff shops are happy to quote over the phone) not a DIY job .... unless you want to spend near the same amount buying parts and tools for the job
    new exhaust $250 (labour not included)
    new extractors (pacemakers) about $400 - $450 (labour not included)
    and a chip you can either get done by som1 on this site for around $100 - $150 or buy from a shop for $400 + (you can put this one in yourself no matter how little you know about cars)
    VT2 Acclaim
    Aug 2005
    and dont forget air filter and roller rockers.
    im looking at sports exhaust, k&n filter, headers, roller rockers, chip, and a dyno tune in that order.... mostly as a cost thing but no point having rockers and chip if it cant breathe.
    Matrix
    jpvx Guest
    VE SSV
    Sep 2005
    Perth, WA
    diff overhaul and ratio change $750 (3:45.1)
    Exhaust and extractors brand new and installed $1200
    Chip installed with calibration for diff ratio change and shift points $400
    K&N Panel filter $120 (install yourself)
    Total $2470 (with $30 change - half a tank of fuel)
    INSAYN's Avatar
    INSAYN is offline INSAYN INSAYN Executive
    1993 VR Calais V8
    Aug 2005
    Wanganui NZ
    Total $2470 (with $30 change - half a tank of fuel)[/QUOTE]
    $30 bucks for half a tank , gas must be cheap over there
    jpvx Guest
    Do K&N air filter
    Top Gun performance leads and Performance Plugs give the car extra kilowatts??
    VE SSV
    Sep 2005
    Perth, WA
    K&N Filter will let the air flow better and will have some gain but will need the extractors and exhaust to make the most of it.
    as for leads and plugs: more for smoother running.
    performance leads and plugs are more for when you do more than just minor mods like you want.
    just change them when they are required when servicing. i dont see the need to spend the money on them unless the car is running rough or missing
  15. #15
    VE SSV
    Sep 2005
    Perth, WA
    Quote Originally Posted by INSAYN
    ok a little under half a tank(from empty light on to FULL)....thats with the more expensive BP Ultimate 98
    it will at least give you a couple of hours of fun to test the new gear out.
  16. #16
    Jun 2005
    Its not really worth spending all that money on a ECOTEC V6.
    Better spending the money on an engine that responds to tuning like a GenIII V8 or a Turbo VL
    The ECOTECH V6 is a slow heap of shit
  17. #17
    VT
    Apr 2005
    QLD
    Quote Originally Posted by Heckel
    we got some friends at a place called "blue-chip tuning" that might beg to differ....
  18. #18
    manual VN aero
    May 2005
    SA
    $2500 would be close to get you a sv6 wich are apparently good for over 400hp with stock internals, would prolly work out better than spending $2500 on your ecotec
  19. #19
    VL-187's Avatar
    VL-187 is offline ZZZZZZZZTUUUTUUUTUUU VL-187 Executive
    XR6 turbo 332rwkw
    Jan 2005
    wot does gear changes do?
    and wot r roller rockers?
    sorry 4 dumb questions lol
  20. #20
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    actualy the v6 allmost puts out twice the amount of hp then the 6tvl
    Powered By Garrett
  21. #21
    VT
    Apr 2005
    QLD
    Quote Originally Posted by VL-187
    gear changes, i assume you mean diff gear changes. changing the ratio of your differential is basically increases or decreases the tractive effort of your car. how many turns of your tailshaft to one full rotation of your wheel. the higher the ratio of your diff i.e the higher the number 3.86, 4.11, the easier it is for your car to turn the wheels. the only downside is the higher you go, the more top end speed you lose, so effectively you have to rev your car more to get the speed out of it. there are a few different types of roller rockers, you can have roller pedestals which are on the ecotecs and rockers with roller tips.............
  22. #22
    TAILS83's Avatar
    TAILS83 is offline alcoholics go to meetings TAILS83 Executive
    VPII Club Sport, Build NO# 339.
    Sep 2003
    Brisbane northside
    Quote Originally Posted by burnz
    i presume you are talking about the VL Turbo 6. stock it put out 150kw at the fly, the next 6cyl motor to put out that much power stock was the VS S/C V6 which was 165kw's. the na ecotec was 147kws. lets not bring the alloytec into it, it's a totally different motor with potential.
    if you put a boost controller on a stock VLT for $50 you would have 200kw's at the fly.
    so yes the ecotec is an out of date P.O.S push rod motor, but i like it.
    Never late, in a 30..4 lol
  23. #23
    VXII SS
    Dec 2005
    NSW
    VLT6 are a wannabe rice boys dream car.. they dont match up to a nice ecotec... and the only thing a VL driver floggs is his long tom..
  24. #24
    TAILS83's Avatar
    Sep 2003
    Brisbane northside
    oh i see, lol!!! you guys were just trying to roll me up hehehehehe!!!
    but yeah in all seriousness, nissan motors can't be laughed at. they have the technology the bastards. if only holden could get a sniff of it.
  25. #25
    Blown VS v6 3.8, 76 LX and VT SS gen3
    Sep 2004
    PERTH
    dude 2500 go to v6supercharged.com there is a set of rollerrockers for like 700 which are 1:9:1 which will change your camspec good 17 at the wheels alot beter then some crappy exhaust (depending on how game you are im putting mine on my self ) MSD coils 1 KW at the wheels
    thats about as much as an exhaustthere about 300 bucks,get some decent leads
    thats a grand
    1500 id change to a lsd dif if you havent got one or convert her to manual
    hell change the sespention or fly to broom for a week your choice
    OH and get a kn
    Anything worth shooting is worth shooting twice. Ammo is cheap. Life is expensive.
+ Reply to Thread
  1. Replies: 18
    Last Post: 01-04-2007, 11:35 AM
  2. cheap mods?
    By V3N0M in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-07-2006, 07:44 PM
  3. Cheap Mods
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2006, 06:59 PM
  4. VP cheap Mods
    By SexGod in forum V6 Development And Modification
    Last Post: 25-08-2005, 05:16 PM
  5. Cheap Mods I Can Do?
    By dumpd6 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-04-2004, 10:52 PM
