Results 1 to 10 of 10
Thread: knocking Noise
    vt commy
    Aug 2005
    Unhappy knocking Noise
    just recently i've noticed a knocking noise from the drivers side wheel. i rocked the steering wheel when the car was parked and off and it made the knocking noise. it somtimes does it when i turn. does anybody have any ideas on what it could be?
    cheers
    impressive's Avatar
    impressive is offline BARRP BARRRRRP
    VT SS 5 litre
    Nov 2005
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Hairy Eater's Avatar
    Hairy Eater is offline Banned
    2000 VX Executive V6
    Nov 2005
    Queensland
    maybe its your tierod joints.... ask a friend to move the steering wheel and you hold your hand on the tierod steering joint... if there's any free play, you should easy feel it..
    vt commy
    Aug 2005
    I just had my brakes Done by repco yesterday and the knocking only started today so the calipers could be it. (did'nt even think of it).
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    Wouldnt be surprised if something was left loose. Jack it up, remove the wheel & have a look. You dont want a brake failure this time of year.(anytime really)
    vt commy
    Aug 2005
    i just checked out the calipers and thats not it. i aint the tierods, and it aint the bearing. so i gunna have to wait till next week to take it the mech
    VS II V6 Berlina
    Nov 2005
    i came across this sort of scenario when i was workimg at holden and found that in many cases it turned out to be feeplay in the steering rack - esp if it happens when car still and turned off. you can adjust the freeplat in the rack pad itself but generally doesn't work most of the time. may possibly be up for new or change over steering rack to eliminate.
    also check 1st to make sure kframe bolts are tight, rack bolts are tight, kframe to chassis braces both side are tight, sway bar bushes aren't flogged out or worn and castor rod bushes are ok.
    hope this helps.
    snowy^ Guest
    Default link in rubbers
    hey mate check the front sway bar link pin bushes.they are the ones that conect the strut to the sway bar..
    vt commy
    Aug 2005
    turns out it was the sway bar bushes.
    cheers guys
  1. VR Knocking Noise.
    By AussieHolden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2006, 07:27 PM
  2. Loud Knocking noise
    By VScom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2006, 03:19 PM
  3. knocking noise VR
    By reckless in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2006, 05:43 PM
  4. VP Knocking BAD noise
    By com123 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2005, 09:45 PM
  5. Knocking noise
    By tkaragia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2005, 07:14 PM
