Results 1 to 7 of 7
Thread: Help. Air con fan turns itself off
    WH Statesman SeriesII 5.7
    Sep 2004
    Default Help. Air con fan turns itself off
    Hi all, am having problems with my air con lately.
    It will be on, working ok, and the the fan turns itself off for a minute or so and then turns itself back on. I also have a cross come up on the climate control every now and then but half the time if the cross is there the aircon is still working alright. just wandering if anyone has had problems like this before.
    BTW. it is a 2002 Statesman with climate
    Thanks in advance
    VS Stato SII L67 S/C V6
    Apr 2004
    the X usually means the sun sensor isnt working
    this is a thing in the middle of your dash
    could be a dry joint or something stupid
    Sep 2004
    Is there a way to check this, what can I do or to I have to take it into holdens.
    Any info would be greatly appreciated.
    I know where the sensor is (I think),
    Could the dashmat covering it make this occur?
    I have cut the dashmat hole bigger for the sensors but maybe it still covers it.
    Apr 2004
    its a round thing between the demister vents
    like a button kinda
    it needs to be not covered
    vr calais
    Feb 2006
    will this sensor stop the air cond from cooling . i just replaced my blower fan and the cross is now showing on my screen (vr calais ) . is the a way to over ride it or do you need to get another one and hope that it had stopped working or then have to look for another problem ?
    Apr 2004
    might be an idea to look at the how to section on how to do a self-diag on the climate control system
    vz wagon
    Mar 2006
    When a X shows in the bottom corner that indicates a fault with ECC.
  1. car turns off
    By BOXTROT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2007, 01:15 PM
  2. air con / fan cant go to 4 (turns off)
    By DJ_TAS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2007, 06:15 AM
  3. car intermittenly turns on
    By kluckmeister in forum General
    Last Post: 08-01-2007, 09:24 AM
  4. VT turns over but will not start
    By brettm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2007, 01:02 AM
  5. Handbrake turns in RWD car?
    By DavidPartay in forum General
    Last Post: 17-08-2004, 07:50 PM
