Does anyone know if you can unlock all doors on a vx commodore executive with a sinlge press rather than a double press?
thats impossible from vt2 onwards
Mate you mean from the VS onwards... heheheheOriginally Posted by WeeMan
On the VY II you have to press twice to unlock all doors. On the Ute/One Tonner, you can lock/unlock the car with a key. You can't even lock/unlock from the inside! Believe me, I've tried to do it myself.
Arrr really damm my VS you had to press it twice, and the same with my VT. Not sure then why hehehehe I just tried it then you have to press it twice.. Oh well, its all good.. CheersOriginally Posted by Charlee
actually on the VS press unlock and it unlocks the driver door and keep it pressed it will open all of them.....
What do you want to drink today?
Ride: VS Acclaim Series 2 + K&n Air Filter
As what some of the others were saying... just hold the button down and they all unlock. Same goes for locking it.
- Gareth
In the VS, Single unlocks drivers side.
Hold it down or Press it again, unlocks all.
Single press on lock - locks everything.
On a Vx II Holden can re-program the computer so all doors unlock after one press
well im pretty sure it wasnt in vt1 (but im probably wrong)Originally Posted by t3zza
BINGO!Originally Posted by Hillbilly
I'm pretty sure this can be done on every model with remotes.![]()
As well as that fact that it "should" unlock all doors when you press and hold.
Just as everyone has stated.
Q. How much is a Ford worth?
A. Depends how much change fell behind the seat.
yes it can be done the dealer needs to reprogram that option in the Body control Module
Rob
VY Series I it is programmed from the options menu. (Press up or down just after the system check) go through options looking for "two stage unlock". Does the VX have an options menu?
