Changing Fuel Filter Plz Help
Mic 'n' son
53
VT Executive S1 V6 98
Ok so we change everything oil, spark plugs etc. and we get to the fuel filter and we cannot figure out how to get it off it.help needed plz
Mic 'n' son :unsure: :confused:
VY03
42
Margaret River
2003 VY Acclaim
To get the fuel filter off you need a special tool as the fittings are a quick release type and repco sells them for about $20 give or take
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Before you remove the filter you must reduce the fuel pressure,if you don't fuel will spray all over the place, possibly in your eyes.To do this you remove the fuel pump relay, start the engine (no throttle) when it stalls, operate the starter for 10 seconds, turn ignition off, replace relay.
6-PAC-ATTACK
44
VT EX S1 3.8L
You dont need tools man save your $$$$ all you do is push and pull thats why they are called quick release iv changed mine since new and never used any tools its to easy :thumbsup:
VTSSDUDE
NSW, Australia
VT SS 5.7L Commodore.
Geez, wish I had known that. I will try it, if I ever need to change mine again.
upthetiggers
Kill Cane Toads!!
40
NSW
VT
Changed mine today, a piece of piss really. And don't worry about back pressure, just have a small rag handy and watch your eyes, its nothing really.
Just don't break the harness that holds the fitler in like I did. A quick cable tie and its back to normal :)
