yz300
- Jul 23, 2016
- 160
- 12
- 18
- Location
- vic
- 1998 vt wagon
Hi fellow holden heads. I have a vt wagon on gas. Once its warmed up and i go to take off it stutters/tries to stall. I have to release the pedal and try again until it goes. I used to ride the brakes to overcome this problem. Since then i.ve worked out by having a switch to turn on low speed cooling fans and using it when i.m stopped and car is fully warm that i never have this problem. It started around the time the fans stopped comming on when you turn the car off and the water gets hot enough. You know how they come on? It also seems as though the car gets hotter before the low speed fans even come on now. Just below half on the gauge. I.ve checked a gazzillion voltages sensors etc with my gregories manual. Although they check out something isnt the way it should be. I feel as though i may need a new temp sensor but if anyone out there has had this problem and fixed it another way can you please give a stumped guy some advice? It will be greatly appreciated. I have reset everything countless times to have it run the way it should for a day or so then go back to its old self. I have also changed plugs n leads plenty of times. Fresh ones in there now. I.ve even swapped the ecu and bcm to no avail after a day or so of driving. Gus.
