Results 1 to 9 of 9
Thread: diff oil change
    vt berlina
    Oct 2005
    Default diff oil change
    hey ive got to change the diff oil in my vt does anyone know how to take it out and where to put the new oil in?
    VT Berlina / HT Sedan (project)
    Nov 2005
    Quote Originally Posted by oliver
    Never changed commodore diff oil, but a few other cars. There should be a couple of plugs in the actual diff case/housing, whatever you call it. Have a look, one fills the other drains.
    VP Exec,honda civic,mazda626
    Jan 2006
    watsonia
    that should be right vs utes have a fill and drain hole my vp only has fill hole
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    Quote Originally Posted by vtdemon
    Yep.. Undo the drain plug and then pump the new oil in the filler plug.. I'm pretty sure you need an oil pump though..
    Shounak
    Always Right
    My Ride
    2003 VY Acclaim
    Jul 2005
    Margaret River
    vt berlina
    Oct 2005
    Nov 2005
    Quote Originally Posted by Italian Stallion
    No harm changing the diff oil as it gets old with time
    It certainly does get OLD with TIME.
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    well you can just undo a few of the bottom bolts and it should start to drain out, when its stopped dripping do them up again, take out the bung with probably a qtr drive and put the new oil into it, the oil level should be up to the level of the bung, so its will leak out but not pure out, just level with it... make sure the car is level while doing it.
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    Hairy Eater's Avatar
    Hairy Eater is offline Banned
    2000 VX Executive V6
    Nov 2005
    Queensland
    worst thing for diff oil is water... when driving the diff gets fairly warm, then if you will acroos a floodway with like 1 foot of water, your diffs cools... causes a vacum and sucks water in through the diff housing air breather.... can suck water in through the wheel bearing seals too...
  1. Diff oil change?
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2008, 03:26 PM
  2. Diff oil change
    By CMA in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-02-2007, 11:20 PM
  3. Diff Oil Change
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2006, 06:20 PM
  4. Help needed on diff change
    By cookie_304 in forum V8 Development and Modification
    Last Post: 17-01-2006, 01:31 PM
  5. how do I change diff gears
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2005, 10:43 PM
