+ Reply to Thread
Results 1 to 7 of 7
Thread: Chewing Out Rear Tyres
    Brumbies 5L is offline Dont Gossip, Just Torque! Brumbies 5L Executive
    VT 5L
    Aug 2005
    Default Chewing Out Rear Tyres
    Hey guys and girls, have been a long time listener but a first time caller, my question to you all is this... my rear tyres are being chewed out, meaning i have hade my 5l for 12 months and have gone through a set of rear tyres already... Yeah yeah can hear that already 5l doing burnouts trash. (Well am middle aged and gone through all that stuff many years ago.....) They are wearing on the inside of the tyre and they are inflated to the correct pressure... 32psi... Any help would be appreciated.....
    Cheers.. The Brumby
    AE86, VE2 SSV M6 UTE
    May 2004
    It is a known issue with the vt's and vx S1. VX series 2 had an updated IRS system which stopped the inside of the tyres getting chewed up. First thing would be to get a camber kit, although it wont completely fix the problem, it will increase the life of the tyres. Basically, if the car is lower to the ground, the camber increases so the wheels get inside tyre wear. Addind weight in the car over the rear wheels increases negative camber on the rear wheels, as does taking off from a standing start (rear end squats).
    Like i said, its a common issue and is up on the forums heaps....
    SUPERV6's Avatar
    SUPERV6 is offline SUPERV6 13.299@101.44 SUPERV6 Executive
    VT 'S' Supercharged V6
    Feb 2004
    Moonta (SA)
    As Nikkojoe said...It's a common problem that plagues all VT and VX1 owners and the lower the suspension overall the worse the problem becomes. A Camber/Toe kit should be on your shopping list...also known as a 4 point IRS kit. Rotate the tyres front to back also on each side to help even the wear long term.
    Try running a little higher tyre pressure too...around 35-38psi.
    You can rep me if I make sense
    Now making 278rwhp/207.5rwkw still NON intercooled
    No new ET yet
    SUPERV6 - Australia's quickest unopened & factory fitted NON intercooled L67
    98 VT 'S' S/C V6 245 rwhp/182.9 rwkw
    Best ET --> 13.299@101.44, 60' 1.834sec
    Visit my SUPERV6 web page or my Cardomain site
    vn exc/vtss
    Oct 2005
    The vt did have a rear camber problem,which should have been rectified in the warranty process.I agree fit a camber kit.Also rear wear on tyres is worse when the car carries a load in the back.cheers
    VT 5L
    Aug 2005
    Thanks for the info... will talk to my local and will see what happens... Why cant other people be so helpful?!?!
    Cheers The Brumby.
    1999 Honda Accord Wagon 2.3 VTEC
    Oct 2005
    Wellington, New Zealand (Yes i know yet another KIWI)
    not all series 1 VT's were effected. My 98 vt wagon doesnt suffer from the problem even when fully loaded with 600+ kgs of stuff in the boot.
    SUPERV6's Avatar
    Feb 2004
    Moonta (SA)
    Individual build quality was a factor. You were lucky and got a good one. Some were so bad that even a Camber/Toe kit struggled to correct the poor build tolerance. I have been lucky with my S1 VT and it never had major rear tyre chewing...but it still suffered to some degree...mostly on the LH rear.
    No new ET yet
+ Reply to Thread
  1. which models had tyre chewing problems?
    By ascension24 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-01-2009, 10:55 AM
  2. rear tyres scrubbing!
    By Sandman240588 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2006, 01:30 PM
  3. Tyre chewing problem solution
    Last Post: 12-06-2006, 03:03 PM
  4. Series 1 VS chewing oil
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-08-2005, 05:25 PM
  5. Chewing up fanbelts
    By Rickvsv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2005, 09:34 PM
