Regarding the right rear door panel...
I have undone all the screws the door is ready to come off, but where the door lock is located,i cannot remove the door or lock from that point!!?
If anyone can help that would be great!!!
Also has anyone any idea how to wire up my new 6" x 9" speakers to the head unit???
..Or can i just wire it to the rear 4" speakers??!!!
just wirer them to the rear ones, would still work but not as good as runnign new wirer`s
Real cars don't power the front wheels, they lift them
There is an orange door lock button retaining clamp in the door lock button. You need to lever this off with a scribe or sharp pointed instrument. You may damage the clamp and it will have to be replaced. Once you've taken the clamp out you will see a retaining screw which should be the last one you need to remove. Diagram below:
