VX SS V8 – 6 speed, my mate’s VX is revving at 1500 to 2000 rpm instead of idling. This problem is intermittent & when it happens if you shut the engine off & restart it, it will then idle at 800 rpm. Holden’s cannot yet figure out what the problem is, just wondering if anyone has encountered this problem.
it might be the computer. it happened to a friends car.
Tried to save myself but myself keeps slippin' away...
My VXII R8
Click Here for VXII S pack
Click Here For My Old Car In vBGarage
check the floormat is not getting stuck up behind the accel. pedal and check the throttle cable is not sticking. Apart from that, sounds like an IAC valve fault. that's if theyve got one![]()
Thanks, I will check.
Yes they have an IAC valve.
Yours Kindly,
Jim
Thanks for the feedback, the problem is resolved. The throttle return valve needed to be replaced, it cost around $45.00 for the genuine GMH part. Sorry my mistake, it cost around $145
throttle return valve is it the same for a V8 as a V6? Whats the part number? And can it be done easily or is a mechanic required?
Thanks
what is a throttle return valve ?
the only valve that controls idle is the idle air contol valve, on the side of the throttle body above the throttle position sensor. it works on its own accord and never touches the throttle plate or throttle assembly, can't be a throttle return valve.
it increases idle when cold, idles back rpm slowly when u back off, moves in and out lettting more or less air in to achieve the RPM being commanded by the pcm for the given situation.
and yes they fail, or become sticky from PCV vapors, sometimes a good clean fixes them.
Sorry for taking so long to reply, when I see my mate I will ask for the part # & send it to you.
My mate still has the Throttle Position Sensor GMH part #17123852.Originally Posted by 235rwkw
Originally Posted by jake_au
I don't know if the V6 has a Throttle Position Sensor GMH part #17123852 but the VX V8 has & replacing this part was the fix. I think this part would be easily replaced by anybody, the problem was finding what caused the fault in the first place.
