Results 1 to 6 of 6
Thread: Body control module. What is it and what does it do???
    VT Wagon
    Oct 2005
    Default Body control module. What is it and what does it do???
    My VT is displaying the engine train light and the airbag light. The mechanic tested the car and told me that the Body module control code is coming up. Does anyone know what the Body module control is and what it does??
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    what code is it exactly? there is no code specifically for body control as you describe.
    the body control module controls the body electrical functions, nothing to do with the airbag?
    try to get the specific code & i will be able to help more
    Rob
    vz wagon
    Mar 2006
    If you have the airbag, engine, abs lights on and tc light on if fitted, you more than likey have an ABS Module fault.
    In the wiring circuit, the ABS is most important hence its first to send and retrieve data, when it has a fault in its module it sets all the other lights on as well as its on light. If you take it to get looked at, the abs wont be able to talk to the test machine and you wont get any codes out of it. Sometimes you are able to disconnect the module and reset it. In some cases when these warning lights come on, you also loose a/c.
    Hope this helps.
    ken
    VT Wagon
    Oct 2005
    Thanks. Would this also cause my fans to run constantly when the warning lights come on?
    vz wagon
    Mar 2006
    VY Ex-cop
    Mar 2006
    Quote Originally Posted by kojamoz
    if you got faulty coolant temp sensor yeah fan can be always on. but hey, i had a VR once with engine light on all the time, had multiple codes, i had to end up pulling the whole loom out to find a broken earth wire in there. but hey i fixed my problem of many fault codes with one earth wire in the middle of the loom that came apart.
  1. VR body control module???
    By gupatrol in forum Electrical Wiring / Questions
    Last Post: 22-01-2008, 09:02 PM
  2. Body control module
    By bluecar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2007, 01:38 AM
  3. Body Control Module????
    By IMCRZY in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2007, 12:33 AM
  4. Body Control Module
    By harvs01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2007, 05:40 PM
  5. Vr & Vs Body Control Module
    By jc58nc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2006, 07:16 AM
