Results 1 to 10 of 10
Thread: VXII S-Pack Clutch Slip
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Unhappy VXII S-Pack Clutch Slip
    Hey,
    Just today i noticed that i've got abit of a clutch slip when i put my foot down.
    Say I'm in 5th on 90, n i put my foot down the RPM goes up heaps, then as it starts dropping i start to speed up heaps....
    My question being,
    Whats the solution, how much, and should i have it looked at urgetly??
    VT S V6 M5
    Sep 2004
    How often does it do it? It used to happen to me a heap when before the clutch burnt out on me on my VT S, i think since i have had it replaced, it happened once not long after i got it, and never since then. You may be looking at a new clutch depending on how often it does it
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    It does it each time i give her abit in any gear.....The rpm goes through the roof n then settles before it actually catches and i get some acceleration...
    Its still under the dealer warranty so he should fix it for me...
    VT S V6 M5
    Sep 2004
    Go and tell them, they will most liely replace it. Mine was under warranty, should be no problems
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    i would have thought clutch wasn't covered by warranty? (just because it's a wearable item, kind of like tires?)
    how many k's has the car done, out of curiosity? have you had it since new?
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Nah, i got the car 2 weeks ago from a used car dealer...
    So its under his 3month, 5000km warranty...
    VT S V6 M5
    Sep 2004
    Have moved up to VE SS
    Jan 2006
    SYDNEY
    Is your car a V6? as the V6 had a dual mass flywheel and if that is stuffed as well this will cost a packet if not covered by warranty.
    paul kafka Guest
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Yeah, duel mass flywheel.
    Yeah..money...lol
    Lucky for me the dealer i used wasn't a total prick so we got the work done for a cheaper price through a mechanic he uses and he also chipped in 400 bux..
    So a new clutch kit, new bolts, seal, etc only cost me 600 bux!
    Instead of the 1200 holden wanted to charge me!
  1. Heavy duty clutch in a VX S-Pack
    By alexvxs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2008, 05:26 PM
  2. New Clutch for VXII S-Pack
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-07-2006, 06:56 PM
  3. VXII S-Pack Cruise Control
    Last Post: 25-02-2006, 03:51 PM
  4. Limited slip in VN.
    By Frd_thmsn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2005, 09:09 AM
  5. Vb To Limited Slip Dif
    By pavelchick in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-07-2005, 12:08 AM
